Browse Forums Building Standards; Getting It Right! Re: Leaking Balcony 2May 19, 2018 11:31 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Leaking Balcony 3May 20, 2018 9:31 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Leaking Balcony 4May 20, 2018 3:19 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking Balcony 6May 22, 2018 8:53 am Weir Good to hear they extended it by 3 years...then what? If the underlying problem isn't fixed..it happens again and you will never be any the wiser as to why it occurred again. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Leaking Balcony 7May 22, 2018 8:56 am Balcony leak is not a structural problem, its a waterproofing problem caused by defective detailing and construction Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking Balcony 8May 22, 2018 9:03 am Brittle tiles don't crack as a result of defective membranes The problem is beneath the membrane? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Leaking Balcony 9May 22, 2018 9:06 am They do if the timber frame swells or if balcony floor is chipboard and got wet and swollen, I have seen it many times. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking Balcony 10May 22, 2018 9:20 am Apartments are Class 2 Buildings Check the engineering & Construction Details the Council should have copies Here in WA Flooring for Balconies & Wet areas should be Compressed cement sheeting Check to see if the builder has substitute materials/details for starters? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Leaking Balcony 11May 22, 2018 9:28 am OP talks about a townhouse with downstairs, implying 2 storey dwelling most likely built as timber frame Townhouse is most likely stand alone and is Class 1, and OP talks about Consumer Affairs which is in Vic. OP did not talk about an apartment. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking Balcony 12May 22, 2018 9:35 am Nobody builds Class 1 Townhouse Balconies using chipboard here and Engineers wouldn't provide such details nor certify the Structural Flooring for Balconies YOUR balcony safe? Engineers warn Melbourne Christmas party collapse that killed two should be a 'wake-up call' to homeowners after a spate of decks crumbling Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Leaking Balcony 13May 22, 2018 11:35 am StructuralBIMGuy Nobody builds Class 1 Townhouse Balconies using chipboard here and Engineers wouldn't provide such details nor certify the Structural Flooring for Balconies YOUR balcony safe? Engineers warn Melbourne Christmas party collapse that killed two should be a 'wake-up call' to homeowners after a spate of decks crumbling Not supposed to be chipboard but I have seen it many times. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24214 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4807 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 3783 |
