Browse Forums Building A New House Re: Building with Wisdom Homes 10791May 15, 2018 10:03 pm MandM+4 Chinoandbebe MandM+4 [quote="Jenifermarie"][quote="MandM+4"][quote="Jenifermarie"]We’re 10 weeks since we went into construction now and we have our ground floor bricks complete plus a bit higher and our scaffold and 2nd brick delivery happened this week. Our brick crew are slower than some of the other builds that have started at the same time as us but we’re still happy with the progress. Just need a few more weeks without rain to get the bricks done and the roof on! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Looking great. You’re only a week behind where we were at week 10. The last bit of bricking probably won’t take much more than a week id say unless there’s rain delays. Yep out SS reckons 4-5 days more of bricks once they’re back later this week so that invoice should be rolling into my inbox before long Hows everything with you? Have you settled in a bit now? I’m starting to think about post handover projects and it’s already feeling like it will go on forever! Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ The bricking was the slowest stage for us, although the roofs took a while with adjusting the scaffolding for the lower, portico and main roofs and the eaves and guttering etc Once internals started contractors were booked pretty much back to back. We are settling in, been living here for a week. Still a little bit to unpack, and my washing machine only got put in today so with 4 kids the house looks like a laundromat. Pendant lights and fans being installed this week but window coverings are still a few weeks away. Concreting starting tomorrow. Hubby doesn’t want to do turf and planting until the spring so will be a while until we are done but plenty to keep us busy until then. Here’s a pic of our leisure room which is the only moved in pic I’ve taken so far, after I had painted. Just need a ceiling fan, sheer curtains and a coffee or side tables to complete this room. Didn’t get new lounges as I wanted to get a feel for the room first but our old lounges don’t look too bad. Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote]Love your leisure room with your lamp on!!! Have you come across many issues since moving in? [/quote] Thanks! Haven’t come across any major issues so far which I am so thankful for. Lots of minor issues, teething problem type stuff like- The aircon was missing a zone, they came back to fix it and one of the vents was blocked. Came back to fix that and put their foot through the ceiling 🤦♀️ The front door handle is a lever instead of bar handle on the inside and the latch is wrong, it isn’t a roller latch so the door locks from the outside without using the key. We’ve asked for this to be changed as it’s too easy to lock ourselves out. The door also lets a lot of air in so I’m going to ask them about that. Sentinel did our antennae, Clipsal did our tv points, so no one thought to connect the 2 together. Again, 🤦♀️. The boys in the household were not happy about having no TV when we moved in! The NBN hadn’t been hooked up either at that stage. But all in all our maintenance list is looking pretty simple *touch wood and we are absolutely loving the house. [/quote]So glad to hear you're loving your new home! Gee they put a foot through your ceiling, that's so clumsy. I would've been annoyed with that. Well I hope that's it for the issues & you can relax & enjoy your new home!!!! Re: Building with Wisdom Homes 10792May 15, 2018 10:09 pm ajayshekar Hello All, Finally got the keys today!! Super excited Some pics attached No major issues, all minor paint touchups etc fixed up between PCI and today. Some remaining things will be fixed in the maintenance period. Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 36 - Wisdom Homes Looks fantastic!what colour are your walls? Re: Building with Wisdom Homes 10793May 15, 2018 10:22 pm MandM+4 Chinoandbebe MandM+4 [quote="Jenifermarie"][quote="MandM+4"][quote="Jenifermarie"]We’re 10 weeks since we went into construction now and we have our ground floor bricks complete plus a bit higher and our scaffold and 2nd brick delivery happened this week. Our brick crew are slower than some of the other builds that have started at the same time as us but we’re still happy with the progress. Just need a few more weeks without rain to get the bricks done and the roof on! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Looking great. You’re only a week behind where we were at week 10. The last bit of bricking probably won’t take much more than a week id say unless there’s rain delays. Yep out SS reckons 4-5 days more of bricks once they’re back later this week so that invoice should be rolling into my inbox before long Hows everything with you? Have you settled in a bit now? I’m starting to think about post handover projects and it’s already feeling like it will go on forever! Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ The bricking was the slowest stage for us, although the roofs took a while with adjusting the scaffolding for the lower, portico and main roofs and the eaves and guttering etc Once internals started contractors were booked pretty much back to back. We are settling in, been living here for a week. Still a little bit to unpack, and my washing machine only got put in today so with 4 kids the house looks like a laundromat. Pendant lights and fans being installed this week but window coverings are still a few weeks away. Concreting starting tomorrow. Hubby doesn’t want to do turf and planting until the spring so will be a while until we are done but plenty to keep us busy until then. Here’s a pic of our leisure room which is the only moved in pic I’ve taken so far, after I had painted. Just need a ceiling fan, sheer curtains and a coffee or side tables to complete this room. Didn’t get new lounges as I wanted to get a feel for the room first but our old lounges don’t look too bad. Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote]Love your leisure room with your lamp on!!! Have you come across many issues since moving in? [/quote] Have you got your keys yet? [/quote]Ha funny.... I'm actually pretty annoyed at how slow our build has been lately. There has been hardly no work on our house for weeks on ends. PCI is suppose to be next week, but that's a joke! There is still so much that needs to be done, too many things to list. I haven't heard from our SS in over 3 weeks. Don't really know what's going on. We've found that nearly everything that we changed or altered on our plan there's been an issue with it. Pretty disappointing actually... Re: Building with Wisdom Homes 10794May 15, 2018 10:24 pm Manhattan52 ajayshekar Hello All, Finally got the keys today!! Super excited Some pics attached No major issues, all minor paint touchups etc fixed up between PCI and today. Some remaining things will be fixed in the maintenance period. Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 36 - Wisdom Homes Looks fantastic!what colour are your walls? PGH Vino with off white mortar Building Ambassador 36 - Wisdom Homes Re: Building with Wisdom Homes 10795May 15, 2018 10:26 pm @Manhattan 52 just realiaed you asked for wall colour not bricks!! :/ Cant remember. Will check tomorrow and let you know. Building Ambassador 36 - Wisdom Homes Re: Building with Wisdom Homes 10796May 15, 2018 10:33 pm twolittlepeas We have received CDC approval hooray!! PS. loving these brick photos! chinoandbebe Will you be having any render/moroka? or leaving it brickface? Our house colours are similar colours to yours, black windows but garage & front door is in surfmist which I'm now second guessing because your dark garage looks so good! Re: Building with Wisdom Homes 10797May 15, 2018 10:36 pm ajayshekar Hello All, Finally got the keys today!! Super excited Some pics attached No major issues, all minor paint touchups etc fixed up between PCI and today. Some remaining things will be fixed in the maintenance period. Cheers. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Ambassador 36 - Wisdom Homes Loving your floorboards! Do you know what colour they are? Re: Building with Wisdom Homes 10798May 15, 2018 10:45 pm Funk52 I like the pics posted of the PGH truffle bricks. I was thinking of going for Espresso because I like dark bricks, but not sure whether it would go well with stone cladding. I have my selections appointments coming up soon so I guess the colour consultant should be able to advise on this. Few photos for your help.....PGH bricks- Espresso, Olympus, Apollo, Volcanic Velour PGH bricks- Olympus, ApolloLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ , PGH bricks- Volcanic Velour, Apollo, EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH bricks- Volcanic Velour, Apollo, EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH bricks- Apollo, Espresso, OlympusLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH bricks- Olympus, ApolloLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ..... [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 10799May 15, 2018 10:52 pm Funk52 I like the pics posted of the PGH truffle bricks. I was thinking of going for Espresso because I like dark bricks, but not sure whether it would go well with stone cladding. I have my selections appointments coming up soon so I guess the colour consultant should be able to advise on this. PGH Espresso... PGH Brick- EspressoPGH Brick- EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH Brick- EspressoPGH Brick- EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH Brick- EspressoPGH Brick- EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ PGH Brick- EspressoLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 10800May 15, 2018 10:54 pm Chinoandbebe Quote: Congrats ajayshekar, your house looks lovely! You must be feeling so happy to finally get your keys! Loving your floorboards! Do you know what colour they are? Thanks Chinoandbebe They are Oakleaf Tawny Building Ambassador 36 - Wisdom Homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 |
