Browse Forums Lighting + Lighting Design Re: Power Point Requirement Whats available and what to choo 3May 14, 2018 6:47 pm arcadelt BigBanjo I have a requirement in the theatre room and office rooms that has to power more than 8 devices. Is there an option to support this through the wall unit. Not sure what you mean by "through the wall unit", but why not just install two quad power points? Sorry I meant the one fixed to wall. Instead of 2 quad ones is there a one with 8 points? Re: Power Point Requirement Whats available and what to choo 4May 14, 2018 6:53 pm BigBanjo Sorry I meant the one fixed to wall. Instead of 2 quad ones is there a one with 8 points? I've never seen one in the specific domestic designs from the big companies, but there are many more options in commercial ranges. However, not all of them are attractive in a domestic housing situation. Is there a specific reason you want something like an eight-gang power point? Often people have TV or media cabinet in front of the points. Is that not what you are doing? It would help if you detailed a bit more what you are trying to achieve. Re: Power Point Requirement Whats available and what to choo 6May 14, 2018 7:00 pm arcadelt BigBanjo Sorry I meant the one fixed to wall. Instead of 2 quad ones is there a one with 8 points? I've never seen one in the specific domestic designs from the big companies, but there are many more options in commercial ranges. However, not all of them are attractive in a domestic housing situation. Is there a specific reason you want something like an eight-gang power point? Often people have TV or media cabinet in front of the points. Is that not what you are doing? It would help if you detailed a bit more what you are trying to achieve. In my theatre I have around 8+ devices for cinema and music Re: Power Point Requirement Whats available and what to choo 8May 14, 2018 8:40 pm Yes you are right. Looks perfect for my needs. Thanks a lot.. By the way how to know if my builder(porter Davis in my case) has this. I know its a stupid question but is there a way to know what they have in terms of the fitting that go into the house(electrical , plumbing and all sorts of things) They have something called Style world but you need to visit in person I guess Re: Power Point Requirement Whats available and what to choo 9May 14, 2018 9:44 pm BigBanjo By the way how to know if my builder(porter Davis in my case) has this. I know its a stupid question but is there a way to know what they have in terms of the fitting that go into the house(electrical , plumbing and all sorts of things) They have something called Style world but you need to visit in person I guess I didn’t build with a volume builder so I don't know for certain, but quad power point are available in many of the major domestic styles. I'd suggest you ring your project manager/site supervisor and ask him what is possible. Failing that, collar the electrician one day when you see him on site and ask him if he can do that kind of setup for you. Re: Power Point Requirement Whats available and what to choo 10Jul 07, 2018 6:13 pm Trader make a 5 gang GPO http://www.gsme.com.au/uploads/download ... _flyer.pdf _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 16160 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6875 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14853 |
