Browse Forums General Discussion Re: Sarking - to sark or not to sark? 2May 09, 2018 8:52 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Sarking - to sark or not to sark? 4May 09, 2018 8:55 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Sarking - to sark or not to sark? 12May 10, 2018 10:50 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Sarking - to sark or not to sark? 14May 11, 2018 12:33 pm I've not had experience with sarking in my previous homes, but have been curious about it as it seems that there are some advantages to potentially be had. With sarking installed, it seems to me that it will put more emphasis on the convenience of accessing your roof cavity via an internal manhole in the ceiling. Is this something that should also be a consideration when choosing to sark or not? In the past, when I've had to get in to my roof, I've kicked back some roof tiles and gone in that way. Am I right to say that sarking would completely stop you from being able to do this? Re: Sarking - to sark or not to sark? 15May 14, 2018 6:58 pm Definitely sarking and wall wrap!!! Houses should not be built with out these!!! Especially tiled roofs!! Batts in the ceiling and external walls also, you'll struggle achieve energy efficiency compliance without. ^^^Man hole best for roof access, much easier and safer than removing tiles and getting up on the roof. Yes sarking will be in the way if you access your roof through the tiles but it beats getting a water leak. Re: Sarking - to sark or not to sark? 16May 17, 2018 8:34 am Thanks everyone! We decided to go with sarking and our builder said the costing would be $2300. I hope they aren't taking us for a ride knowing we need to do it during construction... Does that price seem reasonable? We are building a single level home with an area of about 200m2. Re: Sarking - to sark or not to sark? 17May 17, 2018 8:47 am lys245 Thanks everyone! We decided to go with sarking and our builder said the costing would be $2300. I hope they aren't taking us for a ride knowing we need to do it during construction... Does that price seem reasonable? We are building a single level home with an area of about 200m2. I checked a quote from Metricon for similar size - $2445. Sarking also comes in varying quality so check on that too. Re: Sarking - to sark or not to sark? 19May 17, 2018 10:07 am lys245 Thank you iamsam - I think we are getting heavy duty sarking. Is that what you mean by quality? For example.... https://www.bradfordinsulation.com.au/h ... -roof-type Building Standards; Getting It Right! Hi all I’m in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11727 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6183 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31286 |
