Browse Forums Landscape & Garden Design Re: Help on backyard - are we making the right choice of hou 4May 08, 2018 6:13 pm Where is North? Ideally grass and plants will do best in best sunlight. Pools with solar heating can cope and are often better or of direct sunlight. Opinions differ there though. Re: Help on backyard - are we making the right choice of hou 5May 08, 2018 6:20 pm SteveMc Where is North? Ideally grass and plants will do best in best sunlight. Pools with solar heating can cope and are often better or of direct sunlight. Opinions differ there though. It's north facing. See the image below.. it gets sun most of the day. I think either of the above options would be similar. Just stuck on what is the best layout on looks etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help on backyard - are we making the right choice of hou 6May 08, 2018 6:21 pm Well, in that case it's a matter of personal preference. Re: Help on backyard - are we making the right choice of hou 7May 08, 2018 6:23 pm SteveMc Well, in that case it's a matter of personal preference. Yes I know. We are just torn on which option will look better for a landscaping perspective. IE: WIth the first option the pool is next to the alfresco which means there is a fence 1m away from the alfresco which might make it feel a bit small. The second option the pool is against the house and the alfresco opens up to the grass.. Will that look better. It's our first house so looking for what other people think Re: Help on backyard - are we making the right choice of hou 8May 09, 2018 8:58 am All other things being equal I prefer the updated option. Also, if the pool is right up against the house, you could have a large window to the ground looking out onto the pool and that would be amazing! Re: Help on backyard - are we making the right choice of hou 9May 09, 2018 9:39 am Hillsbuilds All other things being equal I prefer the updated option. Also, if the pool is right up against the house, you could have a large window to the ground looking out onto the pool and that would be amazing! Thanks HillsBuilds, we are in the same mind now. Re: Help on backyard - are we making the right choice of hou 11May 10, 2018 6:16 pm Yes we can but that layout is not what we want. Kitchen and dining together is not ideal. We will go with flipped and comparmse on the sides i think. Also checking with other design options. Thanks for responding ! Re: Help on backyard - are we making the right choice of hou 12May 10, 2018 11:49 pm stevezau Yes we can but that layout is not what we want. Kitchen and dining together is not ideal. ! Agreed. The last thing you want after cooking a meal is to eat it in an adjacent dining area. I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17597 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 6002 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10484 |
