Which lockset was it?
Browse Forums Building A New House Re: Building with Metricon 7101May 04, 2018 12:25 am Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7113May 07, 2018 9:19 pm johar.ankur Met_LibertyVerve Hi all We are 6 months in on a very frustrating build. We are about to go back to square one (or close to it) due to defective building. I have attached some photos of the work that had been signed off by previous Metricon site managers. The work is so far over allowable tolerances that as non builders we have no idea how a "quality" builder can approve this type of work. The issues were highlighted in a report we commissioned with Houspect and to say the least the issues were very concerning. The good news is that we have new construction and site managers and they have acknowledged the poor quality and they are working on rectification plans, however, this will result in delays and I have real doubts we will end up with a "new house" once they take apart what has been installed and put them back together again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Without the report who knows how long the build would have continued before Metricon woke up to the major issues uncovered. The photos are only some of the issues, not all of them. All I would say is ensure that you get an independent inspection for every stage. We struggled to get approval to have the inspection company to come on the site at slab stage and then there was a slight delay getting them onsite following the frame stage. I will provide an update when things are fixed. That’s very concerning as we are also about to start construction in a couple of months!! How’s your experience with Housepect so far? How much do they charge? Houspect have been great to deal with and the costs depends on the home size and how many inspections you would like. I would just give them a call to discuss the options and costs. In obtaining the report we wanted piece of mind that all was good with the build. I expected the report to find some small issues, but nothing of the scale Houspect found. Although Metricon have said they will fix it, I have zero confidence at this stage in their abilities for the rest of the build. If you decide to chose Houspect or not, I would definitely have someone check your build through all major stages. Re: Building with Metricon 7114May 07, 2018 9:25 pm Met_LibertyVerve johar.ankur Met_LibertyVerve Hi all We are 6 months in on a very frustrating build. We are about to go back to square one (or close to it) due to defective building. I have attached some photos of the work that had been signed off by previous Metricon site managers. The work is so far over allowable tolerances that as non builders we have no idea how a "quality" builder can approve this type of work. The issues were highlighted in a report we commissioned with Houspect and to say the least the issues were very concerning. The good news is that we have new construction and site managers and they have acknowledged the poor quality and they are working on rectification plans, however, this will result in delays and I have real doubts we will end up with a "new house" once they take apart what has been installed and put them back together again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Without the report who knows how long the build would have continued before Metricon woke up to the major issues uncovered. The photos are only some of the issues, not all of them. All I would say is ensure that you get an independent inspection for every stage. We struggled to get approval to have the inspection company to come on the site at slab stage and then there was a slight delay getting them onsite following the frame stage. I will provide an update when things are fixed. That’s very concerning as we are also about to start construction in a couple of months!! How’s your experience with Housepect so far? How much do they charge? Houspect have been great to deal with and the costs depends on the home size and how many inspections you would like. I would just give them a call to discuss the options and costs. In obtaining the report we wanted piece of mind that all was good with the build. I expected the report to find some small issues, but nothing of the scale Houspect found. Although Metricon have said they will fix it, I have zero confidence at this stage in their abilities for the rest of the build. If you decide to chose Houspect or not, I would definitely have someone check your build through all major stages. Thanks a lot. We will definitely engage A building inspector once the construction starts. Do you mind me asking which suburb are you building? Re: Building with Metricon 7115May 07, 2018 9:34 pm johar.ankur Met_LibertyVerve Hi all We are 6 months in on a very frustrating build. We are about to go back to square one (or close to it) due to defective building. I have attached some photos of the work that had been signed off by previous Metricon site managers. The work is so far over allowable tolerances that as non builders we have no idea how a "quality" builder can approve this type of work. The issues were highlighted in a report we commissioned with Houspect and to say the least the issues were very concerning. The good news is that we have new construction and site managers and they have acknowledged the poor quality and they are working on rectification plans, however, this will result in delays and I have real doubts we will end up with a "new house" once they take apart what has been installed and put them back together again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Without the report who knows how long the build would have continued before Metricon woke up to the major issues uncovered. The photos are only some of the issues, not all of them. All I would say is ensure that you get an independent inspection for every stage. We struggled to get approval to have the inspection company to come on the site at slab stage and then there was a slight delay getting them onsite following the frame stage. I will provide an update when things are fixed. That’s very concerning as we are also about to start construction in a couple of months!! How’s your experience with Housepect so far? How much do they charge? where are you building in Sydney? what is your site managers name? we did not hire PCO, since our site manager said we don't need one M will do a good job now I am worried after see this photos Re: Building with Metricon 7116May 07, 2018 10:01 pm Kandi johar.ankur Met_LibertyVerve Hi all We are 6 months in on a very frustrating build. We are about to go back to square one (or close to it) due to defective building. I have attached some photos of the work that had been signed off by previous Metricon site managers. The work is so far over allowable tolerances that as non builders we have no idea how a "quality" builder can approve this type of work. The issues were highlighted in a report we commissioned with Houspect and to say the least the issues were very concerning. The good news is that we have new construction and site managers and they have acknowledged the poor quality and they are working on rectification plans, however, this will result in delays and I have real doubts we will end up with a "new house" once they take apart what has been installed and put them back together again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Without the report who knows how long the build would have continued before Metricon woke up to the major issues uncovered. The photos are only some of the issues, not all of them. All I would say is ensure that you get an independent inspection for every stage. We struggled to get approval to have the inspection company to come on the site at slab stage and then there was a slight delay getting them onsite following the frame stage. I will provide an update when things are fixed. That’s very concerning as we are also about to start construction in a couple of months!! How’s your experience with Housepect so far? How much do they charge? where are you building in Sydney? what is your site managers name? we did not hire PCO, since our site manager said we don't need one M will do a good job now I am worried after see this photos I would never take M word for it. That would worry me more. In saying that. Our ss has been so good and on top of things. My private inspector found very minor faults each time. Our ss put a sticker on things that were within tolerance as well. His been great. Metricon need more ss like my one. They really do. Been hearing too many of these horror stories. They need to start hiring decent tradies. My ss never minded a private inspector too. When they are like that. It’s usually cos they have nothing to hide. In fact he appreciates the extra set of eyes. viewtopic.php?t=86597 Re: Building with Metricon 7118May 12, 2018 11:13 pm Hi guys for those who are building with Hebel PowerPanel, when your slab is done, is there a step down around the slab for future Hebel installation? Just got told by my friend about this. And noticed for my slab there is no such slab step down and I’m building with Hebel. Really appreciate any reply Re: Building with Metricon 7119May 12, 2018 11:23 pm SANDYFAN Hi guys for those who are building with Hebel PowerPanel, when your slab is done, is there a step down around the slab for future Hebel installation? Just got told by my friend about this. And noticed for my slab there is no such slab step down and I’m building with Hebel. Really appreciate any reply Yes we had it. Here’s a pic Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where that plastic is it’s there too but covered. viewtopic.php?t=86597 Re: Building with Metricon 7120May 12, 2018 11:31 pm Doulton777 SANDYFAN Hi guys for those who are building with Hebel PowerPanel, when your slab is done, is there a step down around the slab for future Hebel installation? Just got told by my friend about this. And noticed for my slab there is no such slab step down and I’m building with Hebel. Really appreciate any reply Yes we had it. Here’s a pic Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where that plastic is it’s there too but covered. viewtopic.php?t=86597 Thank you Doulton. Seems like my slab site manager forgot to put step down for my build. I’ve sent them emails and now wait and see what they come back to me Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10727 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17330 |
