Browse Forums Building A New House Re: Custom Builders (Sydney - French /Hamptons) under 500k 5May 07, 2018 8:41 am We are looking at a custom build in Sydney as well, and also Hamptons style. Our builder quotes have come in at least $2k/m2 (don’t know what that is in squares). And that’s probably a medium finish too. Just with Alex’s point above, the example given is a reverse brick veneer which we found was also more expensive (but great for thermal efficiency). As you are looking at Hamptons, I assume you will have weatherboard? A lightweight house like that, with suitable insulation will likely be less expensive. So for us we found that RBV would add $60-$100k to the build, so we’ve elected to go with insulated lightweight plus PCMs (phase change materials) for thermal mass. Re: Custom Builders (Sydney - French /Hamptons) under 500k 7May 07, 2018 3:45 pm alexp79 Yes, bricks add up around $100K in total to my friends house. And I believe RBV itself is more costly than normal BV. Don’t know if it’s the process being more labour intensive (gyprock has to be attached to brick rather than wood frames) or the fact that it just isn’t a common method of building in Aust! Re: Custom Builders (Sydney - French /Hamptons) under 500k 8May 07, 2018 4:26 pm Hillsbuilds alexp79 Yes, bricks add up around $100K in total to my friends house. And I believe RBV itself is more costly than normal BV. Don’t know if it’s the process being more labour intensive (gyprock has to be attached to brick rather than wood frames) or the fact that it just isn’t a common method of building in Aust! Different requirements for the slab (no recess needed). Bricks have to be chased for the services installation, although this is just a one day job for a specialist. Gyprock can be generally sticked to the brick with the adhesive, so there is not much price difference with that regard (my friends have decided to go with whitewashed brick interiors though). Re: Custom Builders (Sydney - French /Hamptons) under 500k 9May 07, 2018 7:44 pm Hi anitaB this info might help you. A 35-40 square hamptons style home for under 500k is wishfull thinking unless you do owner builder. I am at tender stage with a few builders building a 40sq hamptons style home and all have come in over 600k just for the build no fencing, blinds, landscapping etc and thats not including the marble look stone benchtops. My budget was 550k so had to increase the budget unfortunately. The shaker cabinetery is $$$$$. Hope this info helps Re: Custom Builders (Sydney - French /Hamptons) under 500k 10May 07, 2018 8:25 pm Tolgz Hi anitaB this info might help you. A 35-40 square hamptons style home for under 500k is wishfull thinking unless you do owner builder. I am at tender stage with a few builders building a 40sq hamptons style home and all have come in over 600k just for the build no fencing, blinds, landscapping etc and thats not including the marble look stone benchtops. My budget was 550k so had to increase the budget unfortunately. The shaker cabinetery is $$$$$. Hope this info helps Its a shame that you can't find a company in-between, theres a gap in the building industry I have found. I don't want to go to these big companies as they mass produce and the finishes are not going be that great. I have gone to so many display homes and cant justify the price and especially the finishes. I will need to go Owner builder by the looks of things but now I have to re evaluate my budget and I have been told today by my broker that I would require 50% of the build cost to go owner builder which is unrealistic in todays world. May I ask which builder you have decided to go with? Photos? I just feel very overwhelmed and stressed out with this whole process and I have not even begun, put it this way once I am done I will create a whole blog to the build to help others as there really is no manual to know who to go with and how to start. I have been told by a lot of our friends to anticipate blowing the budget and you always end up going over. We have left a buffer incase that has happened.... But I just want to find a buffer or middle ground without going to crazy and still achieving some sort of a quality finish. How long did it take you to build? Did you find any price variations? Thank you again for the feedback, really do appreciate it Re: Custom Builders (Sydney - French /Hamptons) under 500k 11May 07, 2018 8:38 pm Hillsbuilds We are looking at a custom build in Sydney as well, and also Hamptons style. Our builder quotes have come in at least $2k/m2 (don’t know what that is in squares). And that’s probably a medium finish too. Just with Alex’s point above, the example given is a reverse brick veneer which we found was also more expensive (but great for thermal efficiency). As you are looking at Hamptons, I assume you will have weatherboard? A lightweight house like that, with suitable insulation will likely be less expensive. So for us we found that RBV would add $60-$100k to the build, so we’ve elected to go with insulated lightweight plus PCMs (phase change materials) for thermal mass. Thank you for shedding some light, its great to know that I am not the only one thinking wow its expensive or am I doing something wrong. I guess that is going rate for a custom build - been told today by a lovely gentlemen not to settle on a builder unless they can provide 5 references. I never even considered that and once he explained everything it all just made sense to me... He basically said not to make a decision unless the builder provided 5 references, meaning builder has to provide a client for each of the following: 1. During Construction (How its kept, how tidy is it, how safe is it, hows it going for budget and any variations, how did they overcome complications and hidden costs. 2. Home thats completed 3. 3 Year old home - See how it stands over the 3 years 4. 5 Years old 5. Out of Warranty Period If any of the builders cant provide 5 clients for the above he told me to run and not look back. It really got me thinking today and it really sunk in for me as I am not only after the finishes but want to rest easy knowing my home will last and won't look shocking after 8-10 years. I am anticipating for maintenance but don't want major problems. In regards to materials, truth is I have not explored any of those options.... I am just trying to gather all my inspiration photos and take them to a builder to show him exactly what we are looking at but just wanted to see if anyone could recommend anyone great. Re: Custom Builders (Sydney - French /Hamptons) under 500k 12May 16, 2018 4:34 pm You get what you pay for in general. 500k is just not enough for a custom home. Even if it’s a project home, at 40sq you will be looking at basic-medium level of finish. Doesn’t sound like that’s what you want though. Maybe try smaller house size or single storey. Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12145 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3680 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16147 |
