Browse Forums Renovation + Home Improvement Re: Replacing standard shower head with a double shower head 3May 03, 2018 7:38 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Replacing standard shower head with a double shower head 5May 05, 2018 7:41 am I would do the same.. doubt i would need a plumber to swap over a simple shower head OT, As many battlers & punters on this forum are aware after entering Contracts some builders/tradesmen will leave you with these options 1. Take it (at a ridiculous price) 2. Leave it and do without 3. Place you in a worse position trying to sort it out later on Always weigh up the options before deciding one way.. or the other.. as there are always better solutions which only become apparent with facts + proofs Thanks for sharing Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9821 Hi there, Looking for any advice or feedback on what is a recommended size for double showers? It's a normal glass shower with a door (not a walk in) and there will be 2… 0 1777 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17714 |
