Browse Forums Renovation + Home Improvement Re: Replacing standard shower head with a double shower head 3May 03, 2018 7:38 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Replacing standard shower head with a double shower head 4May 04, 2018 11:21 am StructuralBIMGuy @pandibabi Ouch $250 (bucks) labour to swap it over? As mentioned what are you going to do when he screw fixes the rail into the tiling...? Ask to have the flexible hose attached dangling & leave off the rail fixing & swap them over yourself. hth I've been asking around, aparently as long as the double shower head I choose uses the one rail, like the Bunnings example, then it will be easy to swap over after the build.. So I might do that.. saves me about $1K.. Re: Replacing standard shower head with a double shower head 5May 05, 2018 7:41 am I would do the same.. doubt i would need a plumber to swap over a simple shower head OT, As many battlers & punters on this forum are aware after entering Contracts some builders/tradesmen will leave you with these options 1. Take it (at a ridiculous price) 2. Leave it and do without 3. Place you in a worse position trying to sort it out later on Always weigh up the options before deciding one way.. or the other.. as there are always better solutions which only become apparent with facts + proofs Thanks for sharing Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 2 8358 |
