Browse Forums Owner Builder Forum 1 Jan 07, 2018 10:52 pm Re: Insulation Batts 9Apr 25, 2018 10:10 pm Searching4 knowledge Twas wondering if anyone can help. I've been looking at insulation batts for walls. Researching on the net, R2 cost about $3.80/ M² and R2.5 is double at about $7.60 /M². They are the same depth at 90mm, one is denser I assume. I'm in Sydney, near the coast but not on it and I was wondering is it worth the the extra cost, which is not going to break the bank but I can think of other things that I would like to spend it on if it is only a negligible difference? It will be in a brick veneer, wrapped with double glazed windows. For the all external walls it is about $900 or $1800 for the R2.5. I was thinking that the 2.5 might be a bit stiffer and maybe they wouldn't slump as easily over time in between the studs giving better long term results. Thanks for any input. Bruce insulation is one of the most important things in a home , its too often overlooked in australia and almost never installed properly. you should have an energy evaluation and report on your home to find out what is the best method. r values dont matter if it isnt installed correctly . Re: Insulation Batts 10Jul 13, 2018 9:00 pm Hey here is an idea I came up with today. I have a raked ceiling that gets to 40 degrees + in the summer under an cement sheet roof. No insulation at all between roof and ceiling material. (used to be a carport and previous owner just turned it into a room. Anyway, I thought to put in some ceiling insulation,...but cannot find what is best. Extruded foil is expensive and ugly...but then , I plan to put gyprock over the wonderful looking raked beams. it is either that or pay air con all summer.( and heating in thewinter) So I say some blanket insulation without foil at bunnings and thought R 2.0 ...not very good, but if I attach some foil sarking to the rolls of insulation that may improve the R value. Any thoughts on that idea. ( I haven't seen better than R 2.,0 rools of ceiling insulation with foil attached. thanks for any input. Re: Insulation Batts 11Jul 13, 2018 9:49 pm If you're gyprocking anyway, you could install batts and hold them in place with string until you get the gyprock up. How deep are the beams? Or if you need to batten out the rafters before gyprocking you might be able to sit the batts on top of the battens. Re: Insulation Batts 12Jul 14, 2018 3:05 pm Thanks for the reply. Yes double up on thickness of battens was an idea. beams are 180mm. What do you think on my idea of laying sarking under the insulation? (silver side down) A couple of my plasterer friends, think that screwwing plaster board to beams is NOT a good idea due to expansion and possible screw heads changing position (pulling thru) and then you need to plaster again. They both recommend metal battens and put gyprock into metal battens. A more solid solution. However, my beams are 30 years old, indoors too....so I think their ideas do not have a lot of merit. Rae Re: Insulation Batts 13Jul 14, 2018 8:46 pm raelph Thanks for the reply. Yes double up on thickness of battens was an idea. beams are 180mm. What do you think on my idea of laying sarking under the insulation? (silver side down) A couple of my plasterer friends, think that screwwing plaster board to beams is NOT a good idea due to expansion and possible screw heads changing position (pulling thru) and then you need to plaster again. They both recommend metal battens and put gyprock into metal battens. A more solid solution. However, my beams are 30 years old, indoors too....so I think their ideas do not have a lot of merit. Rae Like this I presume. I was told they do this for long runs and in wet areas only. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Insulation Batts 14Jul 15, 2018 10:49 am raelph Thanks for the reply. Yes double up on thickness of battens was an idea. beams are 180mm. What do you think on my idea of laying sarking under the insulation? (silver side down) A couple of my plasterer friends, think that screwwing plaster board to beams is NOT a good idea due to expansion and possible screw heads changing position (pulling thru) and then you need to plaster again. They both recommend metal battens and put gyprock into metal battens. A more solid solution. However, my beams are 30 years old, indoors too....so I think their ideas do not have a lot of merit. Rae With 180mm space you could fit slightly compressed R3.5 batts (185mm) or R3.0 (165mm), which would make a very noticeable difference. Not sure foil would be necessary, you also need to be careful using foil in ceilings, if there are any electrical penetrations (lights etc) as the foil is conductive. I would say battens would be a must. Found the answer. The recommended distance is .... 1 4584 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 23106 |
