Browse Forums Building Standards; Getting It Right! Re: Paint Peeling - Plaster too soft? 23Aug 17, 2015 12:43 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Paint Peeling - Plaster too soft? 33Apr 25, 2018 8:38 am LOL...The painters report was a whitewash...get it Meanwhile thousands are left to consider gyprocking over their walls yet another consumer protection/ Building Commission agency failing Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Paint Peeling - Plaster too soft? 34May 12, 2018 2:12 am I have had a representative from the Plasters Association and one from the Painters and Decorators inspect my walls a few weeks ago. No solution was offered to fix the problem. The inspector from the plaster's association did a visual inspection and said it looked fine, it was a paint issue. The painting inspector thought it was both a plaster and a painting issue, the only real solution is to live with it and patch up when you can't put up with the scratches and peels. My paint peels off whenever anything touches the wall (e.g. leather couch), and the paint that comes off has a powdery covering on the back. It is also soft, I have my computer monitor on a swivel stand and turned it too far one day. It dug through the paint and plaster down to the grey render with no damage to my monitor. The paint inspector said he had seen a lot worse jobs than mine, the worst was plaster and paint falling off the wall spontaneously, where as mine needs a minor touch or bump to cause damage. When I have time I was going to try different binder / sealers and paints to see if anything works better. Not feeling great about this whole process... Re: Paint Peeling - Plaster too soft? 35Aug 05, 2018 12:17 pm There is a multitude of variables that can impact. It was always recommended that walls were left 3 months, preferably 12 months so that the whiteset could reabsorb carbondioxide and truly harden. Painters never used to 'seal' walls, instead they would put a fat white coat of white on. The problem with 'sealing' too early or even worse, while walls are wet is the whiteset is denied carbon dioxide to 'harden' the white. Other variables are watering down paint, spray misting paìnt to walls and 'laying off' paint as a laughable two coats. Spraying paint is a new variable of only getting traction the past two decades. *All in my opinion only Re: Paint Peeling - Plaster too soft? 36Aug 05, 2018 12:21 pm If you put sticky tape on plasterboard, it will peel the paint off the plasterboard. The key to good solid plaster whiteset walls are leaving the walls before sealing as long as possible so they may absorb carbon dioxide and harden and dry releasing all moisture. 2 good coats of seal. Then paint. *All in my opinion only Re: Paint Peeling - Plaster too soft? 37Aug 05, 2018 12:26 pm If your walls are soft they may be treated with a 'special formulated ratio' phosphoric acid treatment to harden them. The other option is you drywall your house instead of solid hardwall plaster. Do note however that stickytape will peel paint of plasterboard gypsum sheet. *All in my opinion only Re: Paint Peeling - Plaster too soft? 38Aug 05, 2018 12:39 pm There has been a noteable fall in quality supervision and organisation of housing construction. Houses are slow to start then supervisors try to resolve poor organisation trying to make up their poor time management by painting on wet walls and sometimes the sealer diluted along with poor coverage, sometimes no sealer at all. Worse still, if the paint is diluted with water the paint becomes weak; combined with spray paint poor adhesion can occur. If supervision is abominable and walls are painted fast and wet, diluted with water and other cheap paint, you get a perfect storm of soft plaster and whispy poorly adhered paint sitting on the surface. The whiteset no time to release water, absorb CO2 and harden *All in my opinion only Re: Paint Peeling - Plaster too soft? 39Aug 05, 2018 12:54 pm The reason wet areas have to be waterproofed is moisture ingress via capillary action through the walls destroys the plaster on the back eg. the shower. You all know a leaky pipe destroys plaster so why would a supervisor make a decision to send in the white setters before the walls are dry? Why would a supervisor make the decision to send in the painters to seal freshly whiteset walls or send painters to seal wet walls destroying the plaster whiteset? Whats worse, painters not applying sealer and or watering down paint to save paint. And misting paint via a spray gun onto walls, worse, wet walls. Builder supervisors are called supervisors because they are wholly responsible for the building quality directive process. Builder supervisors are responsible for the outcomes. You dont go back to Holden and blame the paint guy because the paint is peeling. Just like the car maker, the builder is responsible. If the builder starts deflecting. Walk away and contact the Building Commision about a trbunal dispute. Don't waste your time with phones. All communication should be in writing. *All in my opinion only Re: Paint Peeling - Plaster too soft? 40Aug 18, 2018 3:48 pm 3 years later, the paint still peels away from a well sealed (dulux oil based sealer) section of wall. As most others in this thread have concluded, the issue is because the plasterer added things to the render which have leached through the plaster and weakened it. An expensive solution is to plasterboard the whole house. Much better, if you can stomach it, is just to repaint regularly. Wallpaper is another option. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6337 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3327 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5038 |
