Browse Forums Building A New House Re: The Avenues Land Release at Austral NSW 2179 39Apr 23, 2018 7:57 pm Dim Hi All, I'm new to this forum and hope someone from this thread can shed some light. I'm planning to buy a lot from Stage 5 release (Reg- Sep-2019). The lot price is comparatively cheap (322Sqm - 399K). There are 22 lots and they are right in-front of the previous release. The question i have is, there are Two existing residential properties right in-front of these new lots so, are there any risks involved or should i be worried about anything before i buy a lot ? (Attached is the new lot plan.) Thanks In advance Dim Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Gosh - big blocks aren't they!! Re: The Avenues Land Release at Austral NSW 2179 40Sep 13, 2018 11:47 am Hi guys, any progress update you guys received for the project? The last time I checked they said stag 2 is due on FEB 2019 Thank you very much. Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 1217 Just to clarify, I'm not a builder I've read my own council's LEP numerous times and worked with an architect to understand my own lot size and problems. 5 1920 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8625 |
