Browse Forums Building A New House Re: Building with Wisdom Homes 10481Apr 19, 2018 2:44 pm my 2 cents. This is a completely incorrect method to install floating vanities. they are supposed to have an S trap that runs through the wall. Have built heaps of these and never had the pipe work visible through the floor. google" installing floating vanities" and you wont see floor wastes Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 10482Apr 19, 2018 3:40 pm thePurist thePurist psur2357 Hi guys Need some help here. I have issue in the bathroom vanities (upstairs only). I am building Manhattan 35. As you can see in the photos below I have plumbing sticking down below the floating vanity in between the base of the vanity and the floor. I was expecting all plumbing to be concealed within the vanity. I am trying to workout why the plumber did it this way. Anyone who got some knowledge in this would be greatly appreciated. cheers Peter upstair ensuite plumbing below floating vanitiesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ upstair bathroom visible plumbingLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey Peter, Did this issue get resolved? Curious as to what the outcome was as we too have the same issue and I only noticed it after reading your post. We have 4 floating vanities (these went up last week) and 2 of them have this issue where the plumbing is visible underneath the vanities. I have just left my SS a message to notify him of this issue. Lets see whats his response is. I hope it doesn’t delay us a lot Hello Everyone, I had a response from my SS regarding the issue of exposed plumbing under floating vanities. SS: “When the wastes are connected, a small false frame will be installed and then tiled” I will be meeting my SS next week to understand what he means by that. 2 out of 4 vanities have plumbing that’s visible underneath and it is going through the floor while the other 2 have plumbing through the wall and nothing is visible underneath. Not sure why they have done it differently. Has anyone else had this issue? Not sure if I am worrying for nothing Hi I just got this exposed plumbing under floating vanities issue resolved yesterday. A very good outcome. Wisdom said they will fix it so that everything is as per the bathroom drawings. We did discuss about introducing a small false wall frame but wisdom decided just to adjust the upper floor beam framing to work around the plumbing. Hope this helps Re: Building with Wisdom Homes 10483Apr 19, 2018 3:43 pm SejaeD my 2 cents. This is a completely incorrect method to install floating vanities. they are supposed to have an S trap that runs through the wall. Have built heaps of these and never had the pipe work visible through the floor. google" installing floating vanities" and you wont see floor wastes The difficulty with having floating vanities is when it is at the edge of the building of edge of a stair void as there is usually an edge beam. The plumbing usually cant penetrate through edge beam and hence sometimes a thicker wall is built at this location to hide the plumbing or constructing a local false wall. Re: Building with Wisdom Homes 10484Apr 19, 2018 5:23 pm Hey All, does anyone have the majestic 40 detailed plans they can send me? I have the hard copy, looking for soft copy so i can work on it via computer tonight. My rep is away till next week. Re: Building with Wisdom Homes 10485Apr 19, 2018 5:36 pm thePurist thePurist psur2357 Hi guys Need some help here. I have issue in the bathroom vanities (upstairs only). I am building Manhattan 35. As you can see in the photos below I have plumbing sticking down below the floating vanity in between the base of the vanity and the floor. I was expecting all plumbing to be concealed within the vanity. I am trying to workout why the plumber did it this way. Anyone who got some knowledge in this would be greatly appreciated. cheers Peter upstair ensuite plumbing below floating vanitiesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ upstair bathroom visible plumbingLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey Peter, Did this issue get resolved? Curious as to what the outcome was as we too have the same issue and I only noticed it after reading your post. We have 4 floating vanities (these went up last week) and 2 of them have this issue where the plumbing is visible underneath the vanities. I have just left my SS a message to notify him of this issue. Lets see whats his response is. I hope it doesn’t delay us a lot Hello Everyone, I had a response from my SS regarding the issue of exposed plumbing under floating vanities. SS: “When the wastes are connected, a small false frame will be installed and then tiled” I will be meeting my SS next week to understand what he means by that. 2 out of 4 vanities have plumbing that’s visible underneath and it is going through the floor while the other 2 have plumbing through the wall and nothing is visible underneath. Not sure why they have done it differently. Has anyone else had this issue? Not sure if I am worrying for nothing Hi thePurist, psur2357 is spot on with their responses. In some circumstances, a structural beam prevents the floor pipe from penetrating through the beam itself. In these cases, we create a small false wall to conceal the vanity waste pipe. It is tiled over and blends in. However, as psur2357 has noted, sometimes we can find an alternative workaround. If you're not happy with the false wall solution, feel free to send me a direct message with your details and I wll arrange for your SS and ACM to call you to see if there are some alternative options in your case. Regards, Mark Live Your Way Re: Building with Wisdom Homes 10486Apr 19, 2018 5:57 pm Hi Mark (Wisdom Homes) Thanks for your reply. Very good to have wisdom homes on this forum. I think it would be great if the SS points this out to the client during the plumbing installation stage as a lot of clients may not be aware of this as we are all expecting the floating vanity as per the bathroom drawings without any false wall. In my case unfortunately my SS did not pick this up and did not even create a false wall as shown on the photos. But I am happy now that wisdom has resolved my issue by wanting to adjust the floor beams to work around the plumbing which is a very good outcome. regards Peter Re: Building with Wisdom Homes 10487Apr 19, 2018 6:19 pm psur2357 Hi Mark (Wisdom Homes) Thanks for your reply. Very good to have wisdom homes on this forum. I think it would be great if the SS points this out to the client during the plumbing installation stage as a lot of clients may not be aware of this as we are all expecting the floating vanity as per the bathroom drawings without any false wall. In my case unfortunately my SS did not pick this up and did not even create a false wall as shown on the photos. But I am happy now that wisdom has resolved my issue by wanting to adjust the floor beams to work around the plumbing which is a very good outcome. regards Peter Thanks for your feedback Peter. Great points. I will make sure we take this on board. Regards Mark Live Your Way Re: Building with Wisdom Homes 10488Apr 19, 2018 6:21 pm WisdomHomes thePurist thePurist [quote="psur2357"]Hi guys Need some help here. I have issue in the bathroom vanities (upstairs only). I am building Manhattan 35. As you can see in the photos below I have plumbing sticking down below the floating vanity in between the base of the vanity and the floor. I was expecting all plumbing to be concealed within the vanity. I am trying to workout why the plumber did it this way. Anyone who got some knowledge in this would be greatly appreciated. cheers Peter upstair ensuite plumbing below floating vanitiesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ upstair bathroom visible plumbingLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey Peter, Did this issue get resolved? Curious as to what the outcome was as we too have the same issue and I only noticed it after reading your post. We have 4 floating vanities (these went up last week) and 2 of them have this issue where the plumbing is visible underneath the vanities. I have just left my SS a message to notify him of this issue. Lets see whats his response is. I hope it doesn’t delay us a lot Hello Everyone, I had a response from my SS regarding the issue of exposed plumbing under floating vanities. SS: “When the wastes are connected, a small false frame will be installed and then tiled” I will be meeting my SS next week to understand what he means by that. 2 out of 4 vanities have plumbing that’s visible underneath and it is going through the floor while the other 2 have plumbing through the wall and nothing is visible underneath. Not sure why they have done it differently. Has anyone else had this issue? Not sure if I am worrying for nothing Hi thePurist, psur2357 is spot on with their responses. In some circumstances, a structural beam prevents the floor pipe from penetrating through the beam itself. In these cases, we create a small false wall to conceal the vanity waste pipe. It is tiled over and blends in. However, as psur2357 has noted, sometimes we can find an alternative workaround. If you're not happy with the false wall solution, feel free to send me a direct message with your details and I wll arrange for your SS and ACM to call you to see if there are some alternative options in your case. Regards, Mark[/quote] Thanks psur2357 for your response. Glad to know that you are happy with the outcome. Thanks Mark. It is great to see that Wisdom is trying to resolve issues people are facing. Gives me confidence that I made the right choice by choosing Wisdom Homes as my builder. I will definitely get in touch if I need to in the future. Re: Building with Wisdom Homes 10490Apr 19, 2018 7:55 pm Nice. I just drove past and we have bricks delivered as well. But still have an issue with my frames not being complete. Hope it gets sorted soon. Re: Building with Wisdom Homes 10491Apr 19, 2018 9:28 pm Hi Everyone, I am finally embarking on my Wisdom Manhattan44Ens journey and have a question for all you Wisdom Home (soon to be or existing) owners regarding your landscaping. Grass in particular! Given that as a Wisdom customer, you obviously like quality and thats why i think this question is best suited in the Wisdom thread rather than a gardening one. What type of Grass are you all chosing / have chosen/ should have chosen? I am taking a liking to the Palmetto grass, but an keen to hear what you are all doing with your grass surrounding your wonderful Wisdom homes!!! Re: Building with Wisdom Homes 10492Apr 19, 2018 9:35 pm Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 10493Apr 19, 2018 9:40 pm Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Congratulations Jordann!! Another amazingly beautiful house there! So happy for you! Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 10494Apr 19, 2018 9:45 pm Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow wow wow it is stunning!! Congratulations! Be sure to show us how you put your finishing touches to it. All your choices look top class. I’m impressed your upper flooring is such a close match to your stairs. I’m also impressed with how spotless everything looks, I’d be stoked with that, after hearing about what a “builder’s clean” is usually like. TBH I think maybe it’s a good thing CQ didn’t exist for us, as I’m sure our budget would have gone out the window! Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10495Apr 19, 2018 9:53 pm One MandM+4 One Just realised my earlier question was a bit dumb! What I meant was, what are some of the options to have no gap above overhead cupboards? There’ll be a bulkhead and/or dropped ceiling in the kitchen. I’m sure Timpelle would do taller cupboards for you or panelling if that’s what you wanted. Thanks, MandM. Going back old posts, I noticed you don’t have gap. Was this something you specifically asked for and had to pay extra for or did it just come like that? The bulkhead was a standard kitchen inclusion Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10496Apr 19, 2018 9:58 pm doosra Nice. I just drove past and we have bricks delivered as well. But still have an issue with my frames not being complete. Hope it gets sorted soon. I'm sure they'll sort it out quickly, they seem to be on the ball lately! Hopefully we have decent weather in the next couple of weeks 🤞🏻 Re: Building with Wisdom Homes 10497Apr 19, 2018 9:59 pm Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your house looks awesome, time to enjoy settling in now. Re: Building with Wisdom Homes 10498Apr 20, 2018 6:49 am Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hurrah! So glad to see that you’re finally there. It must be such a relief. Hope you have a smooth move now you can finally get all your furniture delivered, Bing Lee will be so happy to give you that fridge Can’t wait to see it all once you have moved in Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 10499Apr 20, 2018 8:34 am Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A couple of questions as I'm building the Manhattan too. Your master ensuite looks diff to the oran park display. I thought the WIR were closed doors? And there should be a wall in between the bath and shower whereas you have a shower screen. Did u choose to have it like that.? Re: Building with Wisdom Homes 10500Apr 20, 2018 9:04 am Jordann Grats everyone on your progress. After many delays I'm glad to say we have received our keys today. There are a few things which needs to be finalised, but its great that we're finally done. While we were at Wisdom head office, we asked for a tour of the Canvas Quarter, WoW the place is great and is massive. It's great that Wisdom has created this all in one place for selections. Everything is there, tiles, bathroom, kitchen, landscaping, electrical, they even have a home theatre. Kind of wished we're building right now. Great work Wisdom. Here's a few photo's from today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here's a few photo's of the Canvas Quarter. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Congrats Jordann!! the house is looking really good !! Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19379 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 74938 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9754 |
