Browse Forums Pools & Spas Re: How to deal with excess water when pool is lower than st 3Apr 19, 2018 12:12 pm Hi @evokE ARCHITECTS. No, this is to manage the overflow from the pool. Because the pool is lower than the street level the build wants to use a rubble pit. I prefer to pump it out to the street. Directly from the pool when it reaches certain level. I can't imagine this would be hard to do. Wouldn't it? Re: How to deal with excess water when pool is lower than st 4Apr 19, 2018 12:21 pm Very rare to have much pool overflow, all pool paving and coping should be sloping away from the pool so if you get 20mm rain the pool should only go up 20mm. With evaporation you really need it to rain hard and heavy for a long time for it to overflow. Below is a link that shows mm of evaporation each day in the table, you lose a lot to evaporation unless you're in full shade. A rubble pit is more than adequate. A pump is overkill, but a sump with a pump that is on a float switch is easily done if you feel like it, it'll just set you back $2k for installation by plumber/electrician. Honestly, you'll be topping up the pool more than worrying about overflow.......... http://www.bom.gov.au/climate/dwo/201803/html/IDCJDW4019.201803.shtml Re: How to deal with excess water when pool is lower than st 5Apr 19, 2018 12:28 pm I'm with you here. The problem is that the builder insists we need to do something to show that we are actively managing water that used fall onto my yard and now falls to the pool. And I really don't wan to have a rubble pit. Re: How to deal with excess water when pool is lower than st 6Jun 22, 2018 11:34 pm gaweleczek Because the pool is lower than the street level the build wants to use a rubble pit. I prefer to pump it out to the street. Are you allowed to send pool water to a rubble pit or to stormwater via the street in QLD??? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to deal with excess water when pool is lower than st 7Jun 25, 2018 2:32 am Actually that is my only option. I can't redirect it to the sewer. It think this is unique to QLD. Re: How to deal with excess water when pool is lower than st 8Jul 07, 2018 5:01 pm Create a rubble pit further down the slope, cover with grass and you wouldn't know its there. the amount of water overflowing is going to be minimal. Secondly, you could block off your overflow when you're using the pool, just make sure you take it out. One thing to think about, if its raining into your pool... its raining everywhere, so don't think you'll have a stoggy area filled with water. what suburb are you in? Wilston? Re: How to deal with excess water when pool is lower than st 9Jul 07, 2018 11:52 pm Hi, These are actually not accepted by Brisbane City Council any more. I'm in Aspley. Re: How to deal with excess water when pool is lower than st 10Jul 08, 2018 8:28 am gaweleczek These are actually not accepted by Brisbane City Council any more. That is also my understanding with rubble pits plus pools should also not be drained to stormwater because of their chemical and/or salt content. There are different regulatory bodies to check, the EPA being one of them. Can it be pumped to a holding tank for later (gravity fed) reuse? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How to deal with excess water when pool is lower than st 11Jul 08, 2018 5:17 pm As long as you're draining less than 5% of your pools water in a controlled manner.. you can drain to stormwater. To make it controlled, put a 2 way valve in line, between the pool and the storm entry. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10247 Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4298 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11376 |
