They use Trend windows
Building Wisdom Aspiration 31 at Willowdale
https://ourwillowdalehome.wordpress.com/
Browse Forums Building A New House Re: Building with Wisdom Homes 10409Apr 15, 2018 10:27 am ASJ1981 Ninsta Cheeky When I went to DL, I was told that wood look tiles are about $80 to $100, does anyone know what the extra laying charge might be? I am talking about the long wooden look tiles. We are also looking at wood look tiles and during one of our visits we were told $90psm for a third off set of $150psm for herringbone 😮 We are hoping this will be significantly lower during our colour appointments as other tiler we requested quotes from quote $70psm laying in a herringbone pattern! You can do your flooring after handover if you prefer (you should receive credit from WH for this). But I think you are required to do wet area tiling with DL. We are considering this, by my only concern is the tiles not being flush to the kitchen cabinets & island and then having to use beading to cover the gaps. We plan on having square set ceilings and windows throughout so I’m not sure if the extra beading would throw the modern look. Building Wisdom Homes Majestic 35 Re: Building with Wisdom Homes 10410Apr 15, 2018 11:23 am Frames work started for us. Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 10411Apr 15, 2018 12:05 pm Funk52 Has anyone selected the solar panels and Tesla battery storage instead of taking the $15k voucher? Looks like a good deal but I would hope that you receive a consultation to review your energy needs before having to decide on this. Agreed - We are doing ours after handover as the largest panels they could do was 6kw which would not generate enough power to use the battery at all. We are getting 15kw on the roof. A lot of people think if they have a battery it will solve all their bills but you need to have enough panels to make this work properly It’s really unfortunate as we would have preferred W to do it so it could be roughed in prior to completion for a much nicer look but not to worry. Re: Building with Wisdom Homes 10412Apr 15, 2018 12:19 pm Ninsta Cheeky When I went to DL, I was told that wood look tiles are about $80 to $100, does anyone know what the extra laying charge might be? I am talking about the long wooden look tiles. We are also looking at wood look tiles and during one of our visits we were told $90psm for a third off set of $150psm for herringbone 😮 We are hoping this will be significantly lower during our colour appointments as other tiler we requested quotes from quote $70psm laying in a herringbone pattern! You mean around $200 per sqm for supply and install?? Re: Building with Wisdom Homes 10413Apr 15, 2018 12:39 pm Ninsta ASJ1981 Ninsta [quote="Cheeky"]When I went to DL, I was told that wood look tiles are about $80 to $100, does anyone know what the extra laying charge might be? I am talking about the long wooden look tiles. We are also looking at wood look tiles and during one of our visits we were told $90psm for a third off set of $150psm for herringbone We are hoping this will be significantly lower during our colour appointments as other tiler we requested quotes from quote $70psm laying in a herringbone pattern! You can do your flooring after handover if you prefer (you should receive credit from WH for this). But I think you are required to do wet area tiling with DL. We are considering this, by my only concern is the tiles not being flush to the kitchen cabinets & island and then having to use beading to cover the gaps. We plan on having square set ceilings and windows throughout so I’m not sure if the extra beading would throw the modern look.[/quote] They install the cabinetry and skirting before doing the main floor tiles anyway, so the finish is no different doing it after handover. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10415Apr 15, 2018 6:29 pm Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks Re: Building with Wisdom Homes 10416Apr 15, 2018 6:33 pm stevezau Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks Yeah. We too did the same. Upstairs is 2.59m. 🙌 Council approval 31/01/2018 Slab 26/03/2018 Outside Plumbing/electrical work done 05/04/2018 Frames started 09/04/2018 Re: Building with Wisdom Homes 10417Apr 15, 2018 6:35 pm Priyasuresh11 stevezau Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks Yeah. We too did the same. Upstairs is 2.59m. 🙌 What about downstairs? 2.74 or 2.59? Re: Building with Wisdom Homes 10418Apr 15, 2018 6:35 pm stevezau Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks My understanding is that they do up to 2.59 m upstairs max. Standard is about 2.4 m upstairs. The upgrade from 2.4 m to 2.59 m is about $5K. Re: Building with Wisdom Homes 10419Apr 15, 2018 6:44 pm stevezau Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks I thought the standard upstairs height is 2440mm and the upgrade is to 2590mm I didnt think you could do 2740 upstairs Re: Building with Wisdom Homes 10420Apr 15, 2018 6:45 pm Cheeky stevezau Hey All, I searched this thread but not that much chat regarding 2.7 ceiling heights (unless I searched wrong). We have 2590m ceiling upstairs and downstairs with square set cornice. Is it worth doing the 2.7 upstairs? I've been told by a few people it's worth the $5k upgrade but not the why it's worth it (other than the obvious).. Does the 15cm make a big difference? What about for upstairs also? Not sure i can justify the cost for upstairs. Thanks My understanding is that they do up to 2.59 m upstairs max. Standard is about 2.4 m upstairs. The upgrade from 2.4 m to 2.59 m is about $5K. Ah ok, yes it's 5k in my quote.. 2.59 it is. It's the downstairs we can't decide if we should go 2.7m for 5k Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18628 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73681 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8602 |
