Browse Forums Heating, Cooling & Insulation Re: Hot Water - Dux Solar Gas Boosted 6Apr 09, 2018 1:09 pm ![]() It is GAS - so perhaps get someone out? Yes, that’s what I would do - someone who is a plumber and gasfitter. Perhaps ring Dux and ask them who their service agent is in your area, then they will know your system and be able to diagnose it. I certainly wouldn’t be giving up your solar system when the price of gas is high and still rising. I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20734 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 15046 ![]() DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25214 |
