Browse Forums DIY, Home Maintenance & Repair Re: Is it possible for me to do this water leak job? 5Apr 09, 2018 12:42 pm Hi Arcadelt, Thank you for the info. Great, I will apply the silicone to seal and see how it goes! There aren't much leak as you have mentioned so I am hoping that this gets resolved after. Will update you Kind Regards, Re: Is it possible for me to do this water leak job? 6May 27, 2018 1:52 pm Hi, You can control the problem temporarily with some tips but for the permanent solution, i think you must reinstall the tiles. You can approach a home maintenance company like HomeGenie they are good in providing masonry services. Re: Is it possible for me to do this water leak job? 7Jul 18, 2018 8:55 am Hi all, Thank you for all your replies. I have applied a silicone as a temporary fix. It has been working so far. I definitely agree with getting a professional to do more permanent job! Will need to save some money for that If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5082 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 |
