Browse Forums Heating, Cooling & Insulation Re: Ventilation in bedrooms with dual glazed windows 39Apr 08, 2018 2:16 am Bels alexp79 I guess this where the BASIX guys are recommending to install ventilation fans into the bathrooms. It it not anyhow regulating requirements for ducted aircon installers. Also, the standard itself seems to be a bit stupid as most people are simply opening up windows at night (in summer) or at day (in winter) to ventilate their houses (for short periods of time mostly). If you have a tight house, you won't be using your aircons days and nights for sure. Regulation of ducted air conditioning installations still falls under the plumbing compliance board in each state as refrigerated air conditioning falls under plumbing. The standard is what industry is required to be working to. Don't like it then give your feedback to a body like Airah for discussion and dissemination when reviewing and revising amendments to the standards. If your shortsightedness of that of your architect means you didn't factor in ventilation requirements then you're stuck with opening windows for ventilation or need bite the bullet and get something like an ERV system. I am struggling to understand what you mean here. Here are my points, please let me know what exactly is not logical: 1) ERV system is a good thing to have, no doubts, but it is not definitely not installed by everyone and is not popular thing at all. 2) People in tight houses and in moderate climatic zones are certainly not using their 12kW+ ducted systems to ventilate their houses day and night, even if installer designed in outside ducts into the installation. If your house is tight and well oriented, you would be running your ducted system may be few days a year if running at all. 3) So unless you have ERV, you are destined to open the windows (i.e. use natural ventilation) in order to ventilate the house. Re: Ventilation in bedrooms with dual glazed windows 40Apr 08, 2018 2:30 am I have started this discussion so that other people retrofitting double glazing into their homes are aware of ventilation requirements. Summer - yes, you can open a window, unless it's too hot and you are running your split system which does not bring any fresh air. In winter its unlikely that you will sleep with an open window. In my test even if I ventilate before bed, 2 adults and a child will bring the CO2 levels above the recommended guidelines I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16249 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7493 |
