Browse Forums Landscape & Garden Design Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 122Apr 04, 2018 7:42 pm Half a day work and I will have nice clear land. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Question time ...please help. Hubby just wants to put 10cm top soil on before lawn .... which I rejected as the ground is extremely very hard so I do need to loosen the ground before top soil goes on top. I'm not trying to make myself harder....I really think I should remove about 10 cm of contaminated top layer. What are your thoughts? Thanks in advance. Build Thread : viewtopic.php?=31&t=81624 Landscaping Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 123Apr 04, 2018 9:17 pm I think for grass 10cm is fine, with the exception if its stiff clay and the ground doesn't drain. Then I would punch holes in it and work it a bit as man i hated our backyard getting so cloggy! Also with the exception that 10cm is enough to level and gently fall it. For garden beds though nope not suitable, but you already knew that . I wouldn't necessarily remove soil, just remove rocks, glass, metal and rubble as you find it. Work though gypsum, horse poo, garden soil, into the existing dirt. Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 124Apr 04, 2018 9:53 pm cat_dunc I think for grass 10cm is fine, with the exception if its stiff clay and the ground doesn't drain. Then I would punch holes in it and work it a bit as man i hated our backyard getting so cloggy! Also with the exception that 10cm is enough to level and gently fall it. For garden beds though nope not suitable, but you already knew that . I wouldn't necessarily remove soil, just remove rocks, glass, metal and rubble as you find it. Work though gypsum, horse poo, garden soil, into the existing dirt. Thanks cat_dunc. Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 125Apr 05, 2018 3:52 pm Personally the grass will cope with the top 10cm in underlay so long as you try and spread some conditioner on the surface prior to covering. I used several bags of active8 which really worked a treat. For the garden beds I dug( actually jack hammered the clay twice the size and depth) for the lilly Pilly's and just mulched about 200mm which really softened the surrounding clay. Any organic topping will encourage moisture for fauna to colonize the ground and mix / open the clay. I followed a principle that fu/ garden whisperer shares on this community with great success. To excavate and remove 100mm of perfectly recoverable soil only to replace with questionable garden mix would be expensive and wasteful. I strongly recommend watching a documentary back to Eden. Sustainable principles in practical terms. https://vimeo.com/28055108 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 126Apr 05, 2018 6:51 pm SteveMc Personally the grass will cope with the top 10cm in underlay so long as you try and spread some conditioner on the surface prior to covering. I used several bags of active8 which really worked a treat. For the garden beds I dug( actually jack hammered the clay twice the size and depth) for the lilly Pilly's and just mulched about 200mm which really softened the surrounding clay. Any organic topping will encourage moisture for fauna to colonize the ground and mix / open the clay. I followed a principle that fu/ garden whisperer shares on this community with great success. To excavate and remove 100mm of perfectly recoverable soil only to replace with questionable garden mix would be expensive and wasteful. I strongly recommend watching a documentary back to Eden. Sustainable principles in practical terms. https://vimeo.com/28055108 Thank you SteveMc, I will go back to Mr Fu garden whisperer thread. Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 127Apr 15, 2018 1:07 am I have been scratching my head for retaining wall for the side of my house. After long research there are two solution suited for the side of the house and my budget. 1. For the side next to the house along the fence.... I'm thinking... H steel post with H4 treated pine. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2. For the slope back garden will be similar to pic below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 128Apr 16, 2018 8:45 am Plan for driveway. ( all green area to be concreted) We now have more quotes for driveway. To me this is a big project and I only have one written quote the others didn't supply written quotes 1. $11500 - includes driveway, footpaths and crossover, no written quote (to pay cash) referred by my sister and I'm worried 2. $16500 - includes driveway, footpaths, colour mix in concrete and crossover, written quote provided 3. $13000 - includes driveway, footpaths, colour spray on top, crossover and 11 meters of colorbond fence on one side. no written quote ( to pay cash) referred by neighbour. 4. $22000 - he just looked our drawing and said $22000 and to call him if we are interested!! I got to get more written quotes!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 129Apr 16, 2018 1:55 pm I went out to check out plants at Plantplus at Peakhurst. mainly looking for Lilly Pilly. Oh man these plants are not cheap! $29 per pot ...Needed 10 pots... No I didn't buy any... going to check out other places.. On my way out saw chook poo bags on sale. So I loaded 8 bags of chook poo at the back of 4wd... LOL I had to stick my head out of car's window for fresh air on the way back. Next time I will get it delivered direct to my place .... no more chook poo in my car LOL Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 130Apr 16, 2018 5:14 pm Flower power have most varieties of lily pilly's (300mm) for $17 I think. Check them out Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 131Apr 16, 2018 6:33 pm Seen this place recommended a few times. Might be a bit far for you...they also do online ordering http://www.downesnursery.com.au Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 132Apr 16, 2018 9:35 pm SteveMc Flower power have most varieties of lily pilly's (300mm) for $17 I think. Check them out ehhc Seen this place recommended a few times. Might be a bit far for you...they also do online ordering http://www.downesnursery.com.au Thanks guys, yes I will be looking at wholesale nursery places. I also needs 7 pots of camellia Sasanqua Paradise Blush, 15 dwarf lilly pilly and 10 'straight and narrow' lilly pilly. I don't wants to order online ... I like to select my own plants and loves to visit these large nursery also get extra other plants too. Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 133Apr 18, 2018 9:38 pm I don't know when SS will call for handover, but now I'm extremely busy with getting quotes for many different things. Driveway, flooring, fence and retaining wall. Got some timber retaining wall quotes for sloping ground at the back. OMG just simple timber retaining wall. Nothing fancy just 30 metres long ...One guy didn't even take any measurement and verbally $10,000 to do retaining wall !! two more quotes to come tomorrow. I should have become cat_dunc's apprentice... so I can do my own retaining wall. Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 134Apr 18, 2018 9:49 pm I’m going to give treated pine retaining a crack myself... Been watching this video haha https://youtu.be/_4GTLt_y4oM Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 135Apr 19, 2018 11:34 am ehhc I’m going to give treated pine retaining a crack myself... Been watching this video haha https://youtu.be/_4GTLt_y4oM Yes that was one of many youtube clips I have taken notes on... DIY retaining wall haha Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 136Apr 19, 2018 5:29 pm Landscaping = Money Pit received two more quotes from professionals. I flip out of my chair after seeing the cost of retaining wall. Build Thread : viewtopic.php?=31&t=81624 Landscaping Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 137Apr 19, 2018 7:35 pm Yeah?? How much were the quotes? Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 138Apr 19, 2018 8:37 pm haha retaining walls cost a BOMB. Its insane, but oh man its time consuming so thats probably why. I reckon you can do it Shazaw!! Get your sons into the yard How many m2 is your concreting? Has anyone worked it out? I could probably scale it in CAD for you if you needed to know. Its great you're doing a footpath. Man i wish we had one! Even if it goes nowhere as no one else has one I LOVE that wholesale plant place. I just ordered a plant price list Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 139Apr 19, 2018 10:07 pm ehhc Yeah?? How much were the quotes? The first quote was $10000. The second quote $12500 The third quote $23500 Prices for just timber retaining wall, majority of cost goes toward labour. In my initial cost of building, I have not budgeted $$$ into landscaping. Assuming I can do landscaping easily (well that was 2011 when we got this land) I have not consider my age at all...most likely I was feeling under 40 years olds at that time. Now that we are in year of 2018 and I do feels the aging process Oh my ... every digit that's added on to 50 feels like extra 5 years added on. My knees are not in good shape, can't run, can't walk fast, can't carry heavy staff... so not quite sure how I will manage to do digging and moving soil. Slow and steady is my current motto. So to anyone thinking of building please do consider the high cost of landscaping. My retaining wall plans are simple ... very tempting to do DIY. I'm very seriously thinking to do retaining wall for the back fence myself ( doesn't matter how long its take to do it just have to follow my motto - slow and steady ) let's see how I go. Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Re: Landscape design - KDR (sekisui house ) Burbank - ST Geo 140Apr 19, 2018 10:25 pm cat_dunc haha retaining walls cost a BOMB. Its insane, but oh man its time consuming so thats probably why. I reckon you can do it Shazaw!! Get your sons into the yard How many m2 is your concreting? Has anyone worked it out? I could probably scale it in CAD for you if you needed to know. Its great you're doing a footpath. Man i wish we had one! Even if it goes nowhere as no one else has one I LOVE that wholesale plant place. I just ordered a plant price list We are thinking of going with $13k quote for driveway even if they don't provide paperwork. My neighbour is a builder and he has recommended to this concretor . I can always knock on my neighbour's door if any problem arise. Build Thread : viewtopic.php?=31&t=81624 Landscape Thread : viewtopic.php?f=19&t=86133 Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are… 0 3155 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37142 |
