Browse Forums Outdoor Living Re: Pergola design advice 4Apr 03, 2018 11:38 am Thanks for the photos BTW...Rafter sizes are more like 120 x 35mm Do you want concealed bracket fixings to fascia make sure the brackets are fixed/screwed through Fascia and into Rafter ends hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Pergola design advice 5Apr 03, 2018 6:22 pm StructuralBIMGuy Thanks for the photos BTW...Rafter sizes are more like 120 x 35mm Do you want concealed bracket fixings to fascia make sure the brackets are fixed/screwed through Fascia and into Rafter ends hth Thanks heaps! So fascia brackets off roof rafters will be suitable to fix 125 x 125 pergola rafters? Re: Pergola design advice 6Apr 04, 2018 7:39 am Try one, from the photos the fascias looks to be OK Make sure the fixings at the column base and Column/Beam are very rigid To Resist Bending Most are done with welded Steel SHS for that very reason If there is some flexure then you will need to brace it..hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Pergola design advice 7Apr 05, 2018 4:59 pm StructuralBIMGuy Try one, from the photos the fascias looks to be OK Make sure the fixings at the column base and Column/Beam are very rigid To Resist Bending Most are done with welded Steel SHS for that very reason If there is some flexure then you will need to brace it..hth Thanks again for the advice. Might give one a go as you suggest. Columns are concreted in to 600mm. Plan is also to screen off with horizontal timber battens so should help to brace and resist bending i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8237 Is there a building permit? RU in Victoria? What is the value of the building contract? 1 6838 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29625 |
