Browse Forums Building A New House Re: Dream Metricon Glendale 38 (Sydney)! 5481Apr 02, 2018 9:39 am Q, It shouldn’t be a problem to install roller blinds. The blinds people will know the best way to install them. There’s a few methods they can use. They can install it on the inside of the window frame or on the outside Double roller blinds have to attach on outside of door frame Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Others semi inside or fully inside the frame Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 5482Apr 02, 2018 1:13 pm Thanks Orph, that’s good to know Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Dream Metricon Glendale 38 (Sydney)! 5483Apr 27, 2018 10:33 pm Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Dream Metricon Glendale 38 (Sydney)! 5484Apr 28, 2018 12:34 am Quirmeball1280 Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Dream Metricon Glendale 38 (Sydney)! 5485Apr 29, 2018 1:11 pm Quirmeball1280 Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 5486Apr 29, 2018 5:08 pm Orpheus Quirmeball1280 Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Thanks Orph, would you recommend your antenna installer? Until recently, we didn’t realise that the antenna was not included with the house as we thought the tv points installed around the house would lead somewhere Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Dream Metricon Glendale 38 (Sydney)! 5487Apr 29, 2018 6:32 pm Quirmeball1280 Orpheus Quirmeball1280 Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Thanks Orph, would you recommend your antenna installer? Until recently, we didn’t realise that the antenna was not included with the house as we thought the tv points installed around the house would lead somewhere Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I’m surprised they never mentioned antennas to you in electrical? viewtopic.php?t=86597 Re: Dream Metricon Glendale 38 (Sydney)! 5489Apr 29, 2018 8:24 pm I would guess that DGPO = Double General Purpose Outlet / SGPO = Single General Purpose Outlet Re: Dream Metricon Glendale 38 (Sydney)! 5491Apr 29, 2018 9:22 pm Kandi does any one know what is height of the noggins for the wall mount tv. We were told that the tv sits around 1300mm from the ground so noggins between 1300 to 1600mm should work. Of course it depends on the height of your couch, the height of any tv cabinet or soundbar below the tv, and distance from the tv as well. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Dream Metricon Glendale 38 (Sydney)! 5492Apr 29, 2018 9:27 pm Quirmeball1280 Kandi does any one know what is height of the noggins for the wall mount tv. We were told that the tv sits around 1300mm from the ground so noggins between 1300 to 1600mm should work. Of course it depends on the height of your couch, the height of any tv cabinet or soundbar below the tv, and distance from the tv as well. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Thanks, how do we know position of the noggins after the plaster. do you have a photo how they look like Re: Dream Metricon Glendale 38 (Sydney)! 5494Apr 30, 2018 2:44 am Doulton777 Quirmeball1280 Orpheus [quote="Quirmeball1280"]Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Thanks Orph, would you recommend your antenna installer? Until recently, we didn’t realise that the antenna was not included with the house as we thought the tv points installed around the house would lead somewhere Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I’m surprised they never mentioned antennas to you in electrical? viewtopic.php?t=86597[/quote] They don’t sell antennas in NSW from what I remember. I had to do so mine post handover. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Dream Metricon Glendale 38 (Sydney)! 5495Apr 30, 2018 10:22 am nomnomnom Doulton777 Quirmeball1280 [quote="Orpheus"][quote="Quirmeball1280"]Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Thanks Orph, would you recommend your antenna installer? Until recently, we didn’t realise that the antenna was not included with the house as we thought the tv points installed around the house would lead somewhere Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I’m surprised they never mentioned antennas to you in electrical? viewtopic.php?t=86597[/quote] They don’t sell antennas in NSW from what I remember. I had to do so mine post handover. [/quote] Oh I wonder why viewtopic.php?t=86597 Re: Dream Metricon Glendale 38 (Sydney)! 5496Apr 30, 2018 10:25 am Doulton777 nomnomnom Doulton777 [quote="Quirmeball1280"][quote="Orpheus"][quote="Quirmeball1280"]Hi Orph, when you went for your PCI, how did you check whether you Cat6, phone line, Foxtel, tv cables work? Thanks Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Hey Q, My antenna installer did all the cable/ports testing for us. Thanks Orph, would you recommend your antenna installer? Until recently, we didn’t realise that the antenna was not included with the house as we thought the tv points installed around the house would lead somewhere Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I’m surprised they never mentioned antennas to you in electrical? viewtopic.php?t=86597[/quote] They don’t sell antennas in NSW from what I remember. I had to do so mine post handover. [/quote] Oh I wonder why viewtopic.php?t=86597[/quote] I think it’s a choice thing as there are different options in the market. Plus most people now subscribe to PayTV services so no need for free to air( although not all HD free-to-air channels are not available on Foxtel).... Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 5497Apr 30, 2018 12:45 pm Hey orph! Any updates or new photos for us?? M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Dream Metricon Glendale 38 (Sydney)! 5498May 06, 2018 11:22 am MrsJM Hey orph! Any updates or new photos for us?? Hi JM! Nothing new I’m afraid. We put a halt on decorating the house as we are spending money on a new little one coming next month . There’s 2 new sofas coming next month too for our sitting room. Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 5499May 07, 2018 8:15 am Orpheus MrsJM Hey orph! Any updates or new photos for us?? Hi JM! Nothing new I’m afraid. We put a halt on decorating the house as we are spending money on a new little one coming next month . There’s 2 new sofas coming next month too for our sitting room. Wow! Congrats! That’s awesome news! Sorry if you mentioned that in an earlier post- I’ve been off the grid a bit and must have missed it. I can’t wait to see the nursery. I’m sure it’s stunning and decorated beautifully M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Dream Metricon Glendale 38 (Sydney)! 5500May 07, 2018 8:16 am MrsJM Orpheus MrsJM Hey orph! Any updates or new photos for us?? Hi JM! Nothing new I’m afraid. We put a halt on decorating the house as we are spending money on a new little one coming next month . There’s 2 new sofas coming next month too for our sitting room. Wow! Congrats! That’s awesome news! Sorry if you mentioned that in an earlier post- I’ve been off the grid a bit and must have missed it. I can’t wait to see the nursery. I’m sure it’s stunning and decorated beautifully Hi JM, nah first time we mentioned it Orpheus Building the Metricon Glendale 38|Sydney Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10750 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8204 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17333 |
