Browse Forums Building A New House Re: Coral Homes - Modified Bronte 883Jan 18, 2018 9:02 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 885Jan 27, 2018 7:22 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 887Feb 03, 2018 3:01 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 888Feb 03, 2018 4:51 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes - Modified Bronte 890Feb 04, 2018 10:42 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes - Modified Bronte 891Mar 29, 2018 6:45 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 893Apr 04, 2018 8:08 pm Senior building inspector from Fair trading came today to check our tiles. Wayne from Coral one of the Managers attended. Hmmm...issues with the interpretation of the Australian Standards. Because our contract was issued before the start of 2017, the new standards don't apply. So they have to refer to the 2007 Guide...but it is unclear. We have lippage and that is going to be rectified but as far as the grout spacing over 50% of the tiled area is over 3mm and fixing that by replacing them will not fix the issue. Fair Trading will have an answer to us by Friday because he needs to talk to other professionals in the business. He also wants the Coral National Manager to come here. And so it continues... Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 894Apr 04, 2018 8:53 pm Oh CL I hope they have a suitable solution for you. We have Wayne overseeing some things for us as SS has gone ahead with decisions he was suppose to consult with us on first is your lippage really bad? Ours is quite noticeable in ensuite and water flows back to walls rather than down drain (the tap was not connected properly when turned on & went all over floor). Everything is crossed it’s good news for you Fri but ridiculous they can’t use 2017 standards considering tiling wasn’t done until then ? Re: Coral Homes - Modified Bronte 895Apr 05, 2018 7:27 am BrownDog77 Oh CL I hope they have a suitable solution for you. We have Wayne overseeing some things for us as SS has gone ahead with decisions he was suppose to consult with us on first is your lippage really bad? Ours is quite noticeable in ensuite and water flows back to walls rather than down drain (the tap was not connected properly when turned on & went all over floor). Everything is crossed it’s good news for you Fri but ridiculous they can’t use 2017 standards considering tiling wasn’t done until then ? Thanks BD Lippage is over 1.5mm. The other issues are in the main areas in the kitchen/family/dining. We have same issue as you in the showers as the water pools rather than going down the drain. Wayne (I'm assuming he is the same) came yesterday. He has to talk to the National Manager regarding replacement tiles. Hope your issues get solved. They seem to want to appease the clients but it does wear you down. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 896Apr 05, 2018 2:33 pm Corallake BrownDog77 Oh CL I hope they have a suitable solution for you. We have Wayne overseeing some things for us as SS has gone ahead with decisions he was suppose to consult with us on first is your lippage really bad? Ours is quite noticeable in ensuite and water flows back to walls rather than down drain (the tap was not connected properly when turned on & went all over floor). Everything is crossed it’s good news for you Fri but ridiculous they can’t use 2017 standards considering tiling wasn’t done until then ? Thanks BD Lippage is over 1.5mm. The other issues are in the main areas in the kitchen/family/dining. We have same issue as you in the showers as the water pools rather than going down the drain. Wayne (I'm assuming he is the same) came yesterday. He has to talk to the National Manager regarding replacement tiles. Hope your issues get solved. They seem to want to appease the clients but it does wear you down. Glad they are wanting to help you but hopefully it’s done quickly I wonder if we had the same tiler ?!? Re: Coral Homes - Modified Bronte 897Apr 05, 2018 2:44 pm BrownDog77 Corallake BrownDog77 Oh CL I hope they have a suitable solution for you. We have Wayne overseeing some things for us as SS has gone ahead with decisions he was suppose to consult with us on first is your lippage really bad? Ours is quite noticeable in ensuite and water flows back to walls rather than down drain (the tap was not connected properly when turned on & went all over floor). Everything is crossed it’s good news for you Fri but ridiculous they can’t use 2017 standards considering tiling wasn’t done until then ? Thanks BD Lippage is over 1.5mm. The other issues are in the main areas in the kitchen/family/dining. We have same issue as you in the showers as the water pools rather than going down the drain. Wayne (I'm assuming he is the same) came yesterday. He has to talk to the National Manager regarding replacement tiles. Hope your issues get solved. They seem to want to appease the clients but it does wear you down. Glad they are wanting to help you but hopefully it’s done quickly I wonder if we had the same tiler ?!? Hope not because he was absolutely rubbish. he had a reddish coloured ute. His daughter was his first year apprentice (who may have done the bathrooms... which are badly done as well) Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 898Apr 05, 2018 8:07 pm Corallake BrownDog77 Corallake [quote="BrownDog77"] Oh CL I hope they have a suitable solution for you. We have Wayne overseeing some things for us as SS has gone ahead with decisions he was suppose to consult with us on first is your lippage really bad? Ours is quite noticeable in ensuite and water flows back to walls rather than down drain (the tap was not connected properly when turned on & went all over floor). Everything is crossed it’s good news for you Fri but ridiculous they can’t use 2017 standards considering tiling wasn’t done until then ? Thanks BD Lippage is over 1.5mm. The other issues are in the main areas in the kitchen/family/dining. We have same issue as you in the showers as the water pools rather than going down the drain. Wayne (I'm assuming he is the same) came yesterday. He has to talk to the National Manager regarding replacement tiles. Hope your issues get solved. They seem to want to appease the clients but it does wear you down. Glad they are wanting to help you but hopefully it’s done quickly I wonder if we had the same tiler ?!? Hope not because he was absolutely rubbish. he had a reddish coloured ute. His daughter was his first year apprentice (who may have done the bathrooms... which are badly done as well)[/quote] Oh no we had a young guy white Ute -no daughter Re: Coral Homes - Modified Bronte 899Apr 30, 2018 8:46 pm So the saga continues.... Maintenance week came and went with hardly any of the outstanding issues rectified. Out of the 4 days they only worked two half days. Some of the work they did do needs to be fixed again. This is not to mention the problem with tiling. Fair trading has deemed it defective. The state manager requested that Kspec do an inspection and they picked up more faults on top of what FT did. At least 40% of the tiling needs to be ripped up. FT has set 19 May as the deadline. After my husband rang them regarding when the work would be starting (we need to move furniture and since we will not have access to the downstairs area including kitchen we need to sort stuff out!!!) we were given a possible start of 7th May. Still haven't heard back as to what will be happening, if they have sourced replacement tiles and what access they need and when. Kind of sounds like cr@p to me! Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 900May 01, 2018 6:10 am Corallake So the saga continues.... Maintenance week came and went with hardly any of the outstanding issues rectified. Out of the 4 days they only worked two half days. Some of the work they did do needs to be fixed again. This is not to mention the problem with tiling. Fair trading has deemed it defective. The state manager requested that Kspec do an inspection and they picked up more faults on top of what FT did. At least 40% of the tiling needs to be ripped up. FT has set 19 May as the deadline. After my husband rang them regarding when the work would be starting (we need to move furniture and since we will not have access to the downstairs area including kitchen we need to sort stuff out!!!) we were given a possible start of 7th May. Still haven't heard back as to what will be happening, if they have sourced replacement tiles and what access they need and when. Kind of sounds like cr@p to me! Aren’t they useless. I hope coral paid for k-spec! How do these people have any self-respect looking at defects and saying they are within tolerance?! That’s what NSw mgr did to me... took photos of all the defects on his iPad, then the next thing I know I’m getting emails from higher up telling me that it’s all within tolerance! Your tiling sounds like an absolute nightmare. Like my stairs, it’s like they don’t understand our homes aren’t construction sites anymore for them to come and go as they please, they are functioning bloody homes! Once they start how long do you have to be away for? I reckon out of the 7 weeks maintenance were here there was probably about 5 days work in it. Maybe why I have a tonne of stuff outstanding. You wonder how hard it is for them to tick off a god damn list! It’s so frustrating - you just wonder if anyone at all cares! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14303 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4377 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 76510 |
