Browse Forums Building A New House Re: KDR - Allcastle Homes Grandworth 45 MK2 11Mar 22, 2018 6:31 pm Hi L in my case, there is a street/council pole in front of the house already so adding another pole would mean two poles. for the sack of having a short run of underground wire from the pole to the house within 10 meters is a lot to ask I felt. Not to mention I am in the HFC NBN area so there will be some Cable running from the council pole to the house anyway. for the same reason, I don't need NBN lead in as NBN cable won't be underground but overhanging ( like any existing foxtel cable) They are common Hills hub that looks like an alarms box. https://www.pcworld.idg.com.au/article/ ... new_home_/ I dislike their tactic trying to upgrade you before the electrical appiontment without clear cut understanding of what we are buying into is quite annoying. I plan to have every room wired up with the hub under the stair so it's hidden but very much in the dark if I can do that or not. Re: KDR - Allcastle Homes Grandworth 45 MK2 12Mar 26, 2018 2:32 pm HI All, yes we experienced the same trying to push for the NBN upgrade before the electrical. I didn't get the NBN Hub as we are supplying our own network rack, as i have 24 data points in the house. we did go for the NBN leadin though and also another leadin from the external to the under stairs area where we are putting all the network stuff. Whilst our sales consultant was really good, and the first pre-build consultant was great, they have moved us to another pre-build consultant which we feel is really just pushing the bucks around. we have to chase things up with them constantly as they told us to wait for the electrical appointment for 3 weeks, and no one contacted us, i had to send multiple emails and call back until clipsal called us again to confirm details and they were given the wrong contact details. I just told them we are going to get a building inspector and our 2nd pre-build consultant was asking me what they do? anyways we have started demolition today. anyone left a bit of driveway so the trucks don't damage the council part of the driveway? we did find their pricing for the flooring upgrade to be really excessive, for the same type of flooring it would only cost us around 6-7k to install and they wanted close to 10k. so we just told them to remove all the upstairs flooring. the alfresco area whilst expensive is actually pretty good value since it's tiled and also tiled roof. our friend built with claredon it was 2/3 of the price but it's unfinished so they had to do tiling and all that after. Re: KDR - Allcastle Homes Grandworth 45 MK2 13Mar 26, 2018 6:33 pm Thanks for sharing ymiao. Most timberflooring company charges 80 to 150 per square plus $30 on top for installation. Out NW 37 mk2 first floor is about 166 squares so we’re expecting to pay around $15 to $20k installed outside ( prior bargaining ) . Maybe they spooked me when my color consultant said AC WOULD charge a few grand to adapt the doors etc so the house remains compliant . As such we would lose the lousy $2500 1F carpet CR which reduces our needs. Was quite chocked to see the quote came in around $10k so was quite pleased with it. Shutter cost came in around $6k for all windows except two beds up stairs and playroom and the theatre room which is like 50% cheaper than rough quote Wynstan gave after seeing our plan I am not in NBN HTTP/N but HFC ONLY so there is no need for me to do the NBN LEAD IN I THINK. Please share your home betwork plans and pm me the cost if you don’t mind as plan to have the hub up stairs in the linen cabinet or unused space under stairway. I felt I just need to downstairs networking needs are done properly , then upstairs can be fixed later on. I had a call from Clipsal but funny they left a voice mail saying they are booking me in as per coral homes instead of AC . I will be using housepect I think cost around $2500 for all stages. Re: KDR - Allcastle Homes Grandworth 45 MK2 14Mar 27, 2018 9:27 am just make sure you are getting timber and not laminate, if it's paradot, then it's AC3 laminate which what we were quoted on for 10k. we can get AC3 laminate for around $40 per sqm installed. or $30 if we install it ourself, so the cost wasn't good. my friend installed quickstep ultra after build around 250sqm for 15k and quickstep is on the expensive side for laminate. 80-150 is for engineered or bamboo flooring. you will find the larger the area the cheaper the install. we installing curtains after, already found a few places that does it well on bulk, we getting most of our stuff from lesso home in greenacre. network map i will upload after our clipsal appointment, I don't know how well ventilated the linen upstairs is so decided to put everything in understairs area as we don't use it anyway. yeah we using housepect as well, we not doing the wetarea inspection though, as in NSW the builder need to get a independent inspector to sign off, and the housepect on is visual inspection only. Re: KDR - Allcastle Homes Grandworth 45 MK2 15Mar 29, 2018 10:03 pm Hi, We are also building with All Castle in Blacktown area too. DA and CC done, just waiting for final construction plans (15 days) and then another 4 weeks after that will be hoping for a start on the build. Been ok so far... though whole admin/ selection process seems slow. First signed up for intial tender back in September! I'll be keen to hear others feedback on here and happy to answer any questions that might help others Re: KDR - Allcastle Homes Grandworth 45 MK2 16Mar 29, 2018 11:18 pm Hi cooper , whilst they are slow at least they are not pushy and very accomdative.. Doubt we would get the same treatment if it’s with Clarendon or metricon Re: KDR - Allcastle Homes Grandworth 45 MK2 18Mar 31, 2018 11:44 am metskim Guys can I ask who you used to do demolition and rough estimate I’m in marayong and we are about to do knock down end of june Area dependent but I went with site demo who are the only one came back with a price. Very patience staff and the CDC APPROVAL IS QUICK a month for us for ryde. All up around $29k assuming no rocks or additional asbestos surprises Re: KDR - Allcastle Homes Grandworth 45 MK2 20Apr 04, 2018 10:58 am I used demo C, 24k + additional asbestos 2.3k and vegetation 550 I was given a receipt for dumping it 578 per ton , how to tell whether ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They did a clean job and no rework required AC accept it without any comments during handover my house is small 3 Br brick veneer single storey and a car port. Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 745 Was the offer also on their website? If so, you could check the Wayback Machine. 1 1021 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13450 |
