Browse Forums Landscape & Garden Design Re: Garden (post project build) Sydney-Parramatta 33Mar 17, 2018 2:14 pm SteveMc The grand fence reveal!! So happy with the job. The brick work will get cleaned up in a couple of weeks, but already looks finished. Just a few more steps to finish off the front. 1) 150mm concrete sq drain riser 2) leveling the front yard/ cover-up the footings 3) small garden bed with paver edge behind the wall to plant out some murraya hedging. 4) plant out the garage side garden bed 5) irrigation and lighting install Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ May i ask what sort of troubles you had getting the da approval for your walls, and how you got around it? We'll be facing the same issue with the wall being less than 900mm from the boundary, and I'm dreading it. Re: Garden (post project build) Sydney-Parramatta 34Mar 17, 2018 3:53 pm My troubles were with the certifier. Stupid items that needed to be disputed. Silly money spent on unnecessary approvals and significant costs from sydney water, engineering, and the multiple inspections by the private certifier. Might have been easier going direct to council. Re: Garden (post project build) Sydney-Parramatta 35Mar 17, 2018 4:42 pm Front fence really added curb appeal. What type of plants do you have in mind? Build Thread : viewtopic.php?=31&t=81624 Re: Garden (post project build) Sydney-Parramatta 36Mar 17, 2018 4:57 pm SteveMc My troubles were with the certifier. Stupid items that needed to be disputed. Silly money spent on unnecessary approvals and significant costs from sydney water, engineering, and the multiple inspections by the private certifier. Might have been easier going direct to council. Garden (post project build) Sydney-Parramatta 37Apr 02, 2018 10:00 pm A couple of things ticked off this weekend. Irrigation pit, plumbed and pressure tested. Backbone 19mm poly hooked up. Provisioned the control lines and soldered the 12V garden lighting together. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Planting; Weeping Lilly Pilly (Cascade) Little Ruby Japanese Buxus + Dripper hose connected to front garden zone Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Final mulching Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garden (post project build) Sydney-Parramatta 38Apr 03, 2018 5:25 am SteveMc A couple of things ticked off this weekend. Irrigation pit, plumbed and pressure tested. Backbone 19mm poly hooked up. Provisioned the control lines and soldered the 12V garden lighting together. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Planting; Weeping Lilly Pilly (Cascade) Little Ruby Japanese Buxus + Dripper hose connected to front garden zone Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Final mulching Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Garden (post project build) Sydney-Parramatta 39Apr 03, 2018 7:37 am yoyohv Looking Good! Did you diy? Can you share the plan you followed or guidelines? I am thinking about following the advises on Bunnings website, but the more info the better. Yes. Installed myself. I had a landscaper provision the 20mm pvc main lines during the slab prep. All other kit sourced through bunnings. Advice from friends and research online. I posted the plan earlier in the thread but parts etc are a test in patience at bunnings.... Back and forth between irrigation and plumbing sections. You'll be doing well if you manage to get everything in one visit Re: Garden (post project build) Sydney-Parramatta 40Apr 03, 2018 11:04 am SteveMc yoyohv Looking Good! Did you diy? Can you share the plan you followed or guidelines? I am thinking about following the advises on Bunnings website, but the more info the better. Yes. Installed myself. I had a landscaper provision the 20mm pvc main lines during the slab prep. All other kit sourced through bunnings. Advice from friends and research online. I posted the plan earlier in the thread but parts etc are a test in patience at bunnings.... Back and forth between irrigation and plumbing sections. You'll be doing well if you manage to get everything in one visit Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 |
