Browse Forums Building A New House Re: Who's building with Clarendon?? 18399Mar 09, 2018 10:45 pm SnowLeopard We finalized upgrades. Here is an overview if anyone is interested: Carpet $1900 Upgraded to Gold range with underlay Vertical blinds throughout the house $2300 Air con $7100 Fujitsu 15kw MyAir 5 with 6 zones Individual temperature sensor in each zone, allows you to have different temperature in each zone Electrical $10,600 1 power circuit 6 single power points 7 double power points 4 light circuits 8 tread lights pre-wire only 6 external light points pre-wire only 13 light points upgraded to down lights 48 downlights 1 each, 2-way and 3-way switches 2 ducted ceiling exhaust fans 6 ceiling fan pre-wire with timber noggin and fan controller 1 downlights dimmer Smart home $2200 1 video intercom pre-wire only 1 digital antenna 5 cat5e data points 3 cat6 data points 1 TV wall mount wire conduit Tiles $4700 450x450 to 600x600porcelain tiles to main areas 30x45 to 30x60 wall tiles in 3 bathrooms tiled splash back including behind the range hood wow.. your upgrade for the tiles is considered cheap, but the rest are expensive. My tile upgrade cost me about 15K. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 18400Mar 09, 2018 10:57 pm wentworth33 SnowLeopard We finalized upgrades. Here is an overview if anyone is interested: Carpet $1900 Upgraded to Gold range with underlay Vertical blinds throughout the house $2300 Air con $7100 Fujitsu 15kw MyAir 5 with 6 zones Individual temperature sensor in each zone, allows you to have different temperature in each zone Electrical $10,600 1 power circuit 6 single power points 7 double power points 4 light circuits 8 tread lights pre-wire only 6 external light points pre-wire only 13 light points upgraded to down lights 48 downlights 1 each, 2-way and 3-way switches 2 ducted ceiling exhaust fans 6 ceiling fan pre-wire with timber noggin and fan controller 1 downlights dimmer Smart home $2200 1 video intercom pre-wire only 1 digital antenna 5 cat5e data points 3 cat6 data points 1 TV wall mount wire conduit Tiles $4700 450x450 to 600x600porcelain tiles to main areas 30x45 to 30x60 wall tiles in 3 bathrooms tiled splash back including behind the range hood wow.. your upgrade for the tiles is considered cheap, but the rest are expensive. My tile upgrade cost me about 15K. You must have chosen rectified tiles, they're expensive. We just chose cheapest 600x600 The rest does seem expensive but I had external quotes that we gave to our lender. Looking at these, we got more stuff than we would've got if done after handover so just decided to do it with them and have everything ready when we move in. Killara 28 It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact… 3 9195 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8907 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 22276 |
