Browse Forums Paving & Concreting Re: Brick Paved Driveway- Pavers Sinking 2Mar 09, 2018 8:37 pm Some pictures would help The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Brick Paved Driveway- Pavers Sinking 3Mar 10, 2018 8:05 am Mazzotti01 This seems ridiculous to me and a poor excuse. Before I lodge a building complaint I was hoping to get some advice/ insight on the issue. Cheers! You nailed it..Do you have the builders specifications and paving manufacturers name Check their website for driveway installation recommendations Did you take photos and noted the work when it was being done? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick Paved Driveway- Pavers Sinking 5Mar 11, 2018 9:45 pm StructuralBIMGuy Mazzotti01 This seems ridiculous to me and a poor excuse. Before I lodge a building complaint I was hoping to get some advice/ insight on the issue. Cheers! You nailed it..Do you have the builders specifications and paving manufacturers name Check their website for driveway installation recommendations Did you take photos and noted the work when it was being done? I don't have the builders specifications but I do have the paving manufacturers name- Atlas pavers. I had a look at their paving guidelines which are shown below. I suppose I should pull up and edge paver and see if the builder has abided by these edge restraint guidelines. But even if they have, they must have not set the base or compacted properly for the edge to have collapsed...... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick Paved Driveway- Pavers Sinking 6Mar 17, 2018 6:54 pm This is due to poor haunching otherwise called edge restraints. From the photos I'd guess you're in WA ? There's a six year structural warranty on the driveway so if your builder is not coming to the party call the building commission. Your driveway has been haunched with a weak mortar mix. It should be done with concrete for structural stregnth and should extend to a third of the paver width underneath the paver. Regards Shaun Perhaps widen the hole a bit more and insert a nice piece of timber and make it an in counter knife block?? 2 1690 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18566 |
