Browse Forums Building A New House Re: Is this Island bench going to be a overkill? 5Mar 04, 2018 3:54 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Is this Island bench going to be a overkill? 9Mar 04, 2018 6:55 pm Might be worth checking the largest slab size available - my understanding is that Silestone's largest slab size is 325x159cm (see their website at https://www.silestoneoceania.com/silestone-formats/). Unless there's an additional 'hidden' option, it might be worth reducing your length slightly to fit within those dimensions, otherwise you'll end up with a join (which for me, at least, wouldn't be worth it for just 11cm). Re: Is this Island bench going to be a overkill? 11Mar 05, 2018 6:48 am Clean Silestone - Ariel. This looks very close to Frosty Carreena of cesar stone. Engineered stone comes in set sizes. If you want the island bench to remain that long you will probably need to pay for an extra slab and the top will have a join in it. Re: Is this Island bench going to be a overkill? 12Mar 05, 2018 12:29 pm We have selected the same size bench with 80 mm thick stone wrap. I love the large island bench. They look amazing. It’s prob one of my favourite choices in our build shazaw No it is not overkill, It will look very nice!! You will be glad that it's big. My island bench is 3.2m by 1.2m , see pic below just to give you an idea. You will love it. Check if you have enough leg room under bench. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build Thread : viewtopic.php?=31&t=81624 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 106468 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14530 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6628 |
