Browse Forums Building A New House 1 Feb 20, 2018 9:28 pm Hi Can anyone recommend a good building inspector for the Brisbane region, to carry out stage inspections. We are building a double story house soon. Cheers Re: Stage inspections for new build in Brisbane 3Apr 15, 2018 12:15 am symone One for the northern end of the Gold Coast would be great too!! Re: Stage inspections for new build in Brisbane 5Apr 14, 2019 10:25 am I've been using Allinspect - have done slab and frame so far. Very good communication, thorough inspections and couldn't do more to be helpful. Highly recommend them too. Re: Stage inspections for new build in Brisbane 6Apr 30, 2019 6:26 pm Darbecca Qld is who we used and they were excellent. Allinspect are also very good so either of those will give you great service and stick it up those ****** , ******* builders. Go hard on everything but be polite. Re: Stage inspections for new build in Brisbane 7May 13, 2019 4:10 pm KingTaco I've been using Allinspect - have done slab and frame so far. Very good communication, thorough inspections and couldn't do more to be helpful. Highly recommend them too. I've got them on board to. What came up on your slab / prepour? Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Re: Stage inspections for new build in Brisbane 8May 14, 2019 5:17 pm Rhetti KingTaco I've been using Allinspect - have done slab and frame so far. Very good communication, thorough inspections and couldn't do more to be helpful. Highly recommend them too. I've got them on board to. What came up on your slab / prepour? Not a lot of things - some roughness on the edges that met the formwork, which I think all is now covered in brick anyway.. The rebate for the rear sliding door track was rough as, but I think it's concealed now, or at least will be treated at some point if it isn't. The main thing the inspector found was a brick in the edge of the slab - yep in the concrete itself... so for whatever reason, when they poured the concrete they had a brick sitting in the against the formwork. That got cut out and the slab repaired - less than ideal but grateful we hadn't noticed it until the inspector pointed it out. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18199 Not unless you have managed to put it as a special condition into the contract somehow. 1 6204 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8784 |
