Awesome thanks guys. Appreciated. Have asked my sc to include both.
I have got quoted roof sarking at 2000$ for a 49 squares house.
Did you do any upgrade to the insulation or you left it at what they are giving.
Browse Forums Building A New House Re: Porter Davis homes 16402Feb 16, 2018 8:44 pm inphaze fademan Hi guys, great info on the cooling. I'm building a mad45 and didn't get to speak to a cooling consultant through selections because the consultant quit, or was being replaced, at the time. I initially wanted 4 zones, but was told that zoning was strictly for heating only, and cooling is upstairs / downstairs only. At that point I didn't bother with more than the two zones. Heating isn't the expensive bit, so didn't care too much about it. Anyone get different advice, particularly for double storey? I was also told that any additional zones needed to be large (min three ducts) due to the volume of air (was thinking about zoning off my theatre only, for example). Hi Fademan Here is my experience and partial knowledge regarding heating/cooling systems at Porter Davis We had many discussions with the Brivis rep at WOS. She informed us that we would need to upgrade our Heating unit from the 3 Star in our standard inclusions to a 6 Star so we could add refrigeration and zoning. (probably also possible if you upgrade to 5 Star unit, but better cost savings with the 6 star, so we choose that one) With the Brivis 6 star unit you can have up to 4 zones for BOTH heating and cooling. To run heating and cooling through the same ducting system you need to increase the size of the heating ducts provided, from 6 inch to 9 inch. This allows for the greater airflow required for your refrigerated cooling. Once this is done, you can create zones with 2 or more outlets. So it is not usually possible to zone just one room, unless you have 2 outlets in that room. Their pricing is very expensive (no surprise) to create additional zones and their pricing for adding on a refrigerated cooling system is outrageous. We are building a 38 Square house and the quote was 16K. We found a great company who will do this for us post handover and will only cost us $8100 for everything we want done. There are a few things you need to get PD to do during the build, as changes cannot happen downstairs after the build. However they can do anything upstairs after handover. With a double story build, if you require 2 downstairs zones, you need to make sure you have this organised with PD prior to the build, as you need a control cable to manage the control for that zone in that area. For example, we are creating 2 zones in our downstairs area and one zone upstairs. The upstairs zone is controlled via a network controller upstairs which runs back to the main unit in the ceiling. One of the downstairs zones is the Guest bedroom and Guest Ensuite, and the other downstairs zone is All the other rooms downstairs. The large zone will be controlled by a fancy touch screen controller (upgrade) and the other zone has a thermostat only (as PD tell me that I cannot have another network controller installed, just the one upstairs, even though my Air Con guys says he can do 3 network controllers for me). Once I have handover from PD, I will ring my Air Con guy and have him come and install a 17kW refrigeration unit which will bolt onto the heating unit in my upstairs ceiling space. At the same time he will create another zone upstairs (Master Bedroom and Master Ensuite - run via a new network controller) and change the thermostat cable downstairs into another network controller. This will allow me to have 4 zones set throughout my house and have control of each zone from within that zone or via the touch screen. I have also been told that Brivis are in the development stages of creating an App that will also allow you to control your zoners from your phone, however I cannot get 100% confirmation on when this App will actually be launched so I have opted for the manual controls in each zone just in case this App never eventuates. I hope this helps explain what I know about upgrading the heating/cooling systems that Brivis can provide through PD. If you need any further clarification please don't hesitate to ask and I will try to explain further. We paid for the refrig add-on already, which was 16k. I'm going to take this info back to my BC . Maybe the info was based on the 3 star unit. Gives me hope, but I'll be up for a variation fee! Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis homes 16403Feb 16, 2018 8:48 pm fademan inphaze fademan Hi guys, great info on the cooling. I'm building a mad45 and didn't get to speak to a cooling consultant through selections because the consultant quit, or was being replaced, at the time. I initially wanted 4 zones, but was told that zoning was strictly for heating only, and cooling is upstairs / downstairs only. At that point I didn't bother with more than the two zones. Heating isn't the expensive bit, so didn't care too much about it. Anyone get different advice, particularly for double storey? I was also told that any additional zones needed to be large (min three ducts) due to the volume of air (was thinking about zoning off my theatre only, for example). Hi Fademan Here is my experience and partial knowledge regarding heating/cooling systems at Porter Davis We had many discussions with the Brivis rep at WOS. She informed us that we would need to upgrade our Heating unit from the 3 Star in our standard inclusions to a 6 Star so we could add refrigeration and zoning. (probably also possible if you upgrade to 5 Star unit, but better cost savings with the 6 star, so we choose that one) With the Brivis 6 star unit you can have up to 4 zones for BOTH heating and cooling. To run heating and cooling through the same ducting system you need to increase the size of the heating ducts provided, from 6 inch to 9 inch. This allows for the greater airflow required for your refrigerated cooling. Once this is done, you can create zones with 2 or more outlets. So it is not usually possible to zone just one room, unless you have 2 outlets in that room. Their pricing is very expensive (no surprise) to create additional zones and their pricing for adding on a refrigerated cooling system is outrageous. We are building a 38 Square house and the quote was 16K. We found a great company who will do this for us post handover and will only cost us $8100 for everything we want done. There are a few things you need to get PD to do during the build, as changes cannot happen downstairs after the build. However they can do anything upstairs after handover. With a double story build, if you require 2 downstairs zones, you need to make sure you have this organised with PD prior to the build, as you need a control cable to manage the control for that zone in that area. For example, we are creating 2 zones in our downstairs area and one zone upstairs. The upstairs zone is controlled via a network controller upstairs which runs back to the main unit in the ceiling. One of the downstairs zones is the Guest bedroom and Guest Ensuite, and the other downstairs zone is All the other rooms downstairs. The large zone will be controlled by a fancy touch screen controller (upgrade) and the other zone has a thermostat only (as PD tell me that I cannot have another network controller installed, just the one upstairs, even though my Air Con guys says he can do 3 network controllers for me). Once I have handover from PD, I will ring my Air Con guy and have him come and install a 17kW refrigeration unit which will bolt onto the heating unit in my upstairs ceiling space. At the same time he will create another zone upstairs (Master Bedroom and Master Ensuite - run via a new network controller) and change the thermostat cable downstairs into another network controller. This will allow me to have 4 zones set throughout my house and have control of each zone from within that zone or via the touch screen. I have also been told that Brivis are in the development stages of creating an App that will also allow you to control your zoners from your phone, however I cannot get 100% confirmation on when this App will actually be launched so I have opted for the manual controls in each zone just in case this App never eventuates. I hope this helps explain what I know about upgrading the heating/cooling systems that Brivis can provide through PD. If you need any further clarification please don't hesitate to ask and I will try to explain further. We paid for the refrig add-on already, which was 16k. I'm going to take this info back to my BC . Maybe the info was based on the 3 star unit. Gives me hope, but I'll be up for a variation fee! Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis homes 16404Feb 16, 2018 9:23 pm OK team, Inphaze and I have joined the RACE!!! We have temp fencing, a port-a-loo and site scrape, all in one day! 266 days and counting, ETA is 8th of November - it's going to be close! My parents and grandparents have already booked flights from NZ to join us for Christmas and I need the new house finished so I can house them all lol. Question: Should the crossover protection be that short? It looks like its missing half its length. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Porter Davis homes 16405Feb 16, 2018 9:50 pm fademan fademan inphaze Hi Fademan Here is my experience and partial knowledge regarding heating/cooling systems at Porter Davis We had many discussions with the Brivis rep at WOS. She informed us that we would need to upgrade our Heating unit from the 3 Star in our standard inclusions to a 6 Star so we could add refrigeration and zoning. (probably also possible if you upgrade to 5 Star unit, but better cost savings with the 6 star, so we choose that one) With the Brivis 6 star unit you can have up to 4 zones for BOTH heating and cooling. To run heating and cooling through the same ducting system you need to increase the size of the heating ducts provided, from 6 inch to 9 inch. This allows for the greater airflow required for your refrigerated cooling. Once this is done, you can create zones with 2 or more outlets. So it is not usually possible to zone just one room, unless you have 2 outlets in that room. Their pricing is very expensive (no surprise) to create additional zones and their pricing for adding on a refrigerated cooling system is outrageous. We are building a 38 Square house and the quote was 16K. We found a great company who will do this for us post handover and will only cost us $8100 for everything we want done. There are a few things you need to get PD to do during the build, as changes cannot happen downstairs after the build. However they can do anything upstairs after handover. With a double story build, if you require 2 downstairs zones, you need to make sure you have this organised with PD prior to the build, as you need a control cable to manage the control for that zone in that area. For example, we are creating 2 zones in our downstairs area and one zone upstairs. The upstairs zone is controlled via a network controller upstairs which runs back to the main unit in the ceiling. One of the downstairs zones is the Guest bedroom and Guest Ensuite, and the other downstairs zone is All the other rooms downstairs. The large zone will be controlled by a fancy touch screen controller (upgrade) and the other zone has a thermostat only (as PD tell me that I cannot have another network controller installed, just the one upstairs, even though my Air Con guys says he can do 3 network controllers for me). Once I have handover from PD, I will ring my Air Con guy and have him come and install a 17kW refrigeration unit which will bolt onto the heating unit in my upstairs ceiling space. At the same time he will create another zone upstairs (Master Bedroom and Master Ensuite - run via a new network controller) and change the thermostat cable downstairs into another network controller. This will allow me to have 4 zones set throughout my house and have control of each zone from within that zone or via the touch screen. I have also been told that Brivis are in the development stages of creating an App that will also allow you to control your zoners from your phone, however I cannot get 100% confirmation on when this App will actually be launched so I have opted for the manual controls in each zone just in case this App never eventuates. I hope this helps explain what I know about upgrading the heating/cooling systems that Brivis can provide through PD. If you need any further clarification please don't hesitate to ask and I will try to explain further. Thanks for this info, very interesting. We paid for the refrig add-on already, which was 16k. I'm going to take this info back to my BC . Maybe the info was based on the 3 star unit. Gives me hope, but I'll be up for a variation fee! Are you in Melbourne? I wonder if I can change it over after handover? Yes, we are in Melbourne. Using Steve Dale from Dale Air in Dingley Village. (03) 9551 7444 Re: Porter Davis homes 16406Feb 16, 2018 10:15 pm Charly6s OK team, Inphaze and I have joined the RACE!!! We have temp fencing, a port-a-loo and site scrape, all in one day! 266 days and counting, ETA is 8th of November - it's going to be close! My parents and grandparents have already booked flights from NZ to join us for Christmas and I need the new house finished so I can house them all lol. Question: Should the crossover protection be that short? It looks like its missing half its length. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ wow, great start guys... good luck with your build. Re: Porter Davis homes 16407Feb 17, 2018 12:30 pm Hi, We've just realised that we missed the stone in the Galley window reveal. Our BC has kindly informed us it will be a $500 Contract Variation if we go ahead with the change. Since it is going to cost us $500, we are wondering if we can do any other Kitchen changes at the same time for a one off charge of $500. Has anyone bundled multiple changes under the one Contract Variation charge? Re: Porter Davis homes 16408Feb 17, 2018 1:15 pm My latest blog has been posted, it's called Let there be light. https://forsyth35blog.wordpress.com/2018/02/17/let-there-be-light/ This covers the electrical plans with Porter Davis and Argus Electrical. I have also shared all the electrical pricing I have been given, this includes pricing for underfloor heating and the cost or the different sized bathrooms. All the Speaker, projector, NBN, and networking packages that are offered are listed. Along with the individual line items of everything that went into our house. Hopefully, this will help others with budgeting and you enjoy the read. Cheers C. Re: Porter Davis homes 16409Feb 17, 2018 2:53 pm World_Of_Waldorf Good luck Bruce for PCI. May i know whats your exterior render color, looks stunning with the slimline garage door. see more at hoffmangoldwithporterdavis.wordpress.com Re: Porter Davis homes 16410Feb 17, 2018 2:55 pm Fongeo What roof ..? Porter Davis only give tiles and colorbond is an addition, is it worth going to colorbond and is it worth doing roof sarking, have heard colorbond makes it warmer during summer. I am putting a whirlybird does that make any difference ..? Thanks see more at hoffmangoldwithporterdavis.wordpress.com Re: Porter Davis homes 16411Feb 17, 2018 2:56 pm Hurrow For anyone who is looking at getting electricals for their home, it looks like Samsung and Hisense at least are coming out with their new TV models so the current ones are all going on sale. As an added bonus Harvey Norman give you 10% of the purchase value in gift vouchers if you spend over $250, so basically another 10% off. We picked up a 55in HiSense for the rumpus room last night as well as some Arlo Pro 2 security cameras which never go on sale but in this instance have the 10% in gift vouchers. Same prices as at JB HiFi but with 10% in gift cards sounds like a pretty good deal to me! In other news they appear to have done at least one coat of render to the front of our house so we have a better idea of what it will actually look like. Hopefully only a few weeks till PCI! see more at hoffmangoldwithporterdavis.wordpress.com Re: Porter Davis homes 16412Feb 17, 2018 5:38 pm brucefil2011 Fongeo What roof ..? Porter Davis only give tiles and colorbond is an addition, is it worth going to colorbond and is it worth doing roof sarking, have heard colorbond makes it warmer during summer. I am putting a whirlybird does that make any difference ..? Thanks see more at hoffmangoldwithporterdavis.wordpress.com Looks pretty good Re: Porter Davis homes 16413Feb 17, 2018 6:09 pm brucefil2011 Fongeo What roof ..? Porter Davis only give tiles and colorbond is an addition, is it worth going to colorbond and is it worth doing roof sarking, have heard colorbond makes it warmer during summer. I am putting a whirlybird does that make any difference ..? Thanks see more at hoffmangoldwithporterdavis.wordpress.com Looks good maybe put in my current home and see how it goes. G Re: Porter Davis homes 16414Feb 17, 2018 6:54 pm Charly6s My latest blog has been posted, it's called Let there be light. https://forsyth35blog.wordpress.com/2018/02/17/let-there-be-light/ This covers the electrical plans with Porter Davis and Argus Electrical. I have also shared all the electrical pricing I have been given, this includes pricing for underfloor heating and the cost or the different sized bathrooms. All the Speaker, projector, NBN, and networking packages that are offered are listed. Along with the individual line items of everything that went into our house. Hopefully, this will help others with budgeting and you enjoy the read. Cheers C. Another great post Charly, thanks for that! $4k in electrical for a 2 story house seems a ridiculously low estimate by your SC, our SC put in $5k plus $2k for the NBN ready stuff which included 4 sets of two data and tv points and that's for a single story house. We did consider putting in more of each but ended up just leaving it as is, so TV points in the Master, Theatre, Lounge and Rumpus rooms. It's bad for kids to have TVs in their rooms anyway right? We also didn't do much with downlights etc except in the living areas which I think a lot of people spend money on. We thought about doing all the pre-wiring for the theatre room at least but in the end I decided to go with a Sonos system instead, so no wiring required although you do still need the power points for each speaker and the sub. Plus that way to add anything on anywhere in the house at a later date we just need to buy more speakers and add them on. The Porter Davis charge of $520.72 seemed really expensive for 5.1 pre-wiring for basically running twenty or thirty metres of cable! PD didn't seem to have much in the way of smart home stuff or what they did have seemed really expensive. We're going to be doing Arlo cameras, the Sonos system and potentially a Ring doorbell. We may also look into some Hue lightbulbs or the equivalent at some point. Building a Kew 28 with Porter Davis Re: Porter Davis homes 16415Feb 18, 2018 6:15 am Charly6s My latest blog has been posted, it's called Let there be light. https://forsyth35blog.wordpress.com/2018/02/17/let-there-be-light/ This covers the electrical plans with Porter Davis and Argus Electrical. I have also shared all the electrical pricing I have been given, this includes pricing for underfloor heating and the cost or the different sized bathrooms. All the Speaker, projector, NBN, and networking packages that are offered are listed. Along with the individual line items of everything that went into our house. Hopefully, this will help others with budgeting and you enjoy the read. Cheers C. Awesome posts! What are your thoughts on the WIR? I find the builders selection quite limited. Re: Porter Davis homes 16416Feb 18, 2018 8:55 am Morning All, I advised our SS that we would be having at independent inspector at PCI and this was the response. "I will let you know when the pci date will be but before I book in a date you will have to get the your independent through. I must have your independent report at pci. After I receive this and we go through his items and your pci I will advise a approx. handover date, I cant give you a handover date until all this has happened. I will advise you a date to get your independent through when the house is completed" Does this seem right? The whole idea of PCI is that they are saying the house is complete, but he wants our private inspector to come through before PCI and tell him what's wrong so he can rectify it before PCI. In a way I'm happy about this as the sooner it's done the better but at the same time I think it shouldn't be our inspector that has to tell him what needs to be done. Thoughts? Re: Porter Davis homes 16417Feb 18, 2018 9:16 am nikil Morning All, I advised our SS that we would be having at independent inspector at PCI and this was the response. "I will let you know when the pci date will be but before I book in a date you will have to get the your independent through. I must have your independent report at pci. After I receive this and we go through his items and your pci I will advise a approx. handover date, I cant give you a handover date until all this has happened. I will advise you a date to get your independent through when the house is completed" Does this seem right? The whole idea of PCI is that they are saying the house is complete, but he wants our private inspector to come through before PCI and tell him what's wrong so he can rectify it before PCI. In a way I'm happy about this as the sooner it's done the better but at the same time I think it shouldn't be our inspector that has to tell him what needs to be done. Thoughts? see more at hoffmangoldwithporterdavis.wordpress.com Re: Porter Davis homes 16418Feb 18, 2018 9:18 am brucefil2011 nikil Morning All, I advised our SS that we would be having at independent inspector at PCI and this was the response. "I will let you know when the pci date will be but before I book in a date you will have to get the your independent through. I must have your independent report at pci. After I receive this and we go through his items and your pci I will advise a approx. handover date, I cant give you a handover date until all this has happened. I will advise you a date to get your independent through when the house is completed" Does this seem right? The whole idea of PCI is that they are saying the house is complete, but he wants our private inspector to come through before PCI and tell him what's wrong so he can rectify it before PCI. In a way I'm happy about this as the sooner it's done the better but at the same time I think it shouldn't be our inspector that has to tell him what needs to be done. Thoughts? see more at hoffmangoldwithporterdavis.wordpress.com I’m confident at this stage they don’t use any inspectors Re: Porter Davis homes 16419Feb 18, 2018 9:19 am nikil brucefil2011 nikil Morning All, I advised our SS that we would be having at independent inspector at PCI and this was the response. "I will let you know when the pci date will be but before I book in a date you will have to get the your independent through. I must have your independent report at pci. After I receive this and we go through his items and your pci I will advise a approx. handover date, I cant give you a handover date until all this has happened. I will advise you a date to get your independent through when the house is completed" Does this seem right? The whole idea of PCI is that they are saying the house is complete, but he wants our private inspector to come through before PCI and tell him what's wrong so he can rectify it before PCI. In a way I'm happy about this as the sooner it's done the better but at the same time I think it shouldn't be our inspector that has to tell him what needs to be done. Thoughts? see more at hoffmangoldwithporterdavis.wordpress.com I’m confident at this stage they don’t use any inspectors see more at hoffmangoldwithporterdavis.wordpress.com Re: Porter Davis homes 16420Feb 18, 2018 9:32 am nikil Morning All, I advised our SS that we would be having at independent inspector at PCI and this was the response. "I will let you know when the pci date will be but before I book in a date you will have to get the your independent through. I must have your independent report at pci. After I receive this and we go through his items and your pci I will advise a approx. handover date, I cant give you a handover date until all this has happened. I will advise you a date to get your independent through when the house is completed" Does this seem right? The whole idea of PCI is that they are saying the house is complete, but he wants our private inspector to come through before PCI and tell him what's wrong so he can rectify it before PCI. In a way I'm happy about this as the sooner it's done the better but at the same time I think it shouldn't be our inspector that has to tell him what needs to be done. Thoughts? I think our SS wants the Darbecca inspection before PCI as well, but it's just one day before. That way he can get to work on both the structural stuff that Darbecca focuses on as well as the visual stuff that will want fixed as well (assuming there is much, it's actually been a pretty good job so far). And I could have it the wrong way round as well, he might want the Darbecca inspection the day after official PCI. We've had waaaay more communication with our SS than you have though and the build has been pretty smooth so I'm not worried whether it's a day before or after. Building a Kew 28 with Porter Davis Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12345 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74717 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105603 |
