Browse Forums Building A New House Re: My new home in Capestone Mango Hill with Clarendon Wentw 28Feb 08, 2018 1:32 pm nafeesra Hi kishore we look every where but calredone don't have crestmead for display . I have search on the internet and comes across https://www.facebook.com/pg/ClarendonHo ... 3864491980 4 year ago crestmead 46 for display in capestone display village but we have cheeked they don't have one might they have sold that one. Previously I have asked in rochedale calredone display home how much cost for crestmead 46 with diamond inclusion the sale guy give 420k . now dealing with Ryan on newport he told it would be around 480k . He is little pushing up toward sapphire plus inclusion with summer update package http://www.clarendon.com.au/qld/promoti ... er-of-luxe . Still have not receive a quote . once I receive a quote I will share with you guys . I told him I need 600X600 porcelain rectified tiles . I forget to mention need high ceiling . I have read your bad experience about the tiles . I wan to see what they come up with tiles a carpet. My preference is do tiles and carpet my self . Not sure if they allow electrical supply to the client My 2 cents. Sapphire and Diamond are not same. What you see here in pictures in PDF is not the only thing. You are talking about lot more things like bricks, mortor, electricity down light inclusions, type of cabinets you get, stone bench tops, carpet inclusions, tile inclusions and lot more. Don't go by just what you see there. Choices are lot more different between Sapphire and Diamond. The package you see there doesn't match with diamond inclusions. 3 biggest items you put money for will be electrical, carpet, tiles and cabinets. 1) Cabinets - You get only grain finish with very limited colours in Sapphire. You won't get glossy or sheen finish. Diamond has a lot. 2) Tiles - Sapphire has something called silver range. You will have 6-8 colours mostly in white, brown and grey in that range with the limited size. Diamond has much more where in you get porcelain as well I believe. What all we went to pick which looked good were not allowed in Sapphire inclusions. That is where we shell out more. 3) Carpet - We have the most lean and thin one with very 2-3 cms of underlay. They are hard on feet which you usually see in investment homes. Range had only 5 colours where they are either beige or cream whitish ones. 4) Electrical - I wouldn't even discuss as the variations are lot. I would suggest to ask about every item to show what and how it differs from Sapphire to Diamond. 5) Bricks , roof tiles and mortor - You get limited 6 colour bricks, no flat roof etc..Colour of cement / mortor was default to grey. When we asked for colour to match bricks we shell out 2,500 extra. Ask for both booklets of sapphire and diamond which they talk and initially they will get you hooked with internal looks, but ask about external things as well and you will hook them with this . Good Luck mate.. Re: My new home in Capestone Mango Hill with Clarendon Wentw 29Apr 10, 2018 5:06 pm Hi All Clients building their home with Clarendon: Beware....Just to give you a heads up.....Do your diligent on inspecting what is being installed in your wet areas such as bathrooms, toilet, laundry, powder room. They should be installing all sides of wall linings to be moisture resistant plasterboard as required by BCA but at the moment what they installed in my house is only portion of it and the rest just normal plasterboard similar to bedrooms and hallways. You can say they are doing cost cutting and not being compliant with the industry standard. Take photos of wall installed it as this will be very handy in time to dispute with Clarendon. Re: My new home in Capestone Mango Hill with Clarendon Wentw 30Apr 10, 2018 5:08 pm Can you upload the pictures you have taken ? Re: My new home in Capestone Mango Hill with Clarendon Wentw 31Apr 10, 2018 5:11 pm jrey Hi All Clients building their home with Clarendon: Beware....Just to give you a heads up.....Do your diligent on inspecting what is being installed in your wet areas such as bathrooms, toilet, laundry, powder room. They should be installing all sides of wall linings to be moisture resistant plasterboard as required by BCA but at the moment what they installed in my house is only portion of it and the rest just normal plasterboard similar to bedrooms and hallways. You can say they are doing cost cutting and not being compliant with the industry standard. Take photos of wall installed it as this will be very handy in time to dispute with Clarendon. See this link from CSR gyprock website under FAQ http://www.gyprock.com.au/Pages/Resources/FAQs.aspx Can standard plasterboard be used in wet areas? Can standard plasterboard be used in wet areas? Can standard plasterboard be used in wet areas? No. The added moisture content of the area and Building Code of Australia (BCA) dictates moisture resistant wall lining must be used. dard plasterboard be used in wet areas? Re: My new home in Capestone Mango Hill with Clarendon Wentw 34Jan 06, 2020 8:12 pm Hi mate, How you going? I am planning to build Wentworth 35 design with some modifications. I just read your post and having a second thoughts about building with Clarendon Homes now. - Do you mind telling, how much extra you paid compared 5o your initial cost estimate? - ar3 you happy with the traditional facade? - how does current sapphire option compare against the one you had it in 2017? - did you have to do anything past handover and how much you spent? Re: My new home in Capestone Mango Hill with Clarendon Wentw 35Jan 07, 2020 8:26 am RubyornotRuby Hi mate, How you going? I am planning to build Wentworth 35 design with some modifications. I just read your post and having a second thoughts about building with Clarendon Homes now. - Do you mind telling, how much extra you paid compared 5o your initial cost estimate? - ar3 you happy with the traditional facade? - how does current sapphire option compare against the one you had it in 2017? - did you have to do anything past handover and how much you spent? Hi, we paid quite a bit extra on the original house price. As mentioned in my post, it all depends on your choices. Tradional facade is alright, but not to my liking. The one they showed on website and other paper work didn't match up with final draft. We just left it as it was getting too late to get into things. I am not sure what is in the offering on current sapphire price. Your biggest spend will be kitchen, electrical and tiles. Try to get good bargains on them. Even if they say diamond package has everything included, don't trust them. Ask for exclusions first . post handof, yes we did have few issues but most of them are getting sorted. Re: My new home in Capestone Mango Hill with Clarendon Wentw 36Jan 07, 2020 1:05 pm Hey Kishore, Thank you for the detailed write up of your journey building the house and those pictures are very nice. Congratulations on your home and I hope the journey was a cherishable one. We are in the same boat as you and have shortlisted Clarendon and Wentworth 35 with minimal changes to the plan itself. I was wondering if I could get some pictures of the house after completion and especially the kitchen and living areas. Thanks, BrissyBloke Re: My new home in Capestone Mango Hill with Clarendon Wentw 37Jan 07, 2020 3:10 pm BrissyBloke Hey Kishore, Thank you for the detailed write up of your journey building the house and those pictures are very nice. Congratulations on your home and I hope the journey was a cherishable one. We are in the same boat as you and have shortlisted Clarendon and Wentworth 35 with minimal changes to the plan itself. I was wondering if I could get some pictures of the house after completion and especially the kitchen and living areas. Thanks, BrissyBloke Hi, Had a good nice ride with Clarendon. Depends on how you take it . I took it as fun ride and enjoyed with few annoying moments. I did post quite a few pictures after completion as well. Not sure if you can see the picture with black goose neck tap on sink. If not, click on any picture and just keep moving right. You will see them all. Re: My new home in Capestone Mango Hill with Clarendon Wentw 38Jan 07, 2020 3:36 pm kishore BrissyBloke Hey Kishore, Thank you for the detailed write up of your journey building the house and those pictures are very nice. Congratulations on your home and I hope the journey was a cherishable one. We are in the same boat as you and have shortlisted Clarendon and Wentworth 35 with minimal changes to the plan itself. I was wondering if I could get some pictures of the house after completion and especially the kitchen and living areas. Thanks, BrissyBloke Hi, Had a good nice ride with Clarendon. Depends on how you take it . I took it as fun ride and enjoyed with few annoying moments. I did post quite a few pictures after completion as well. Not sure if you can see the picture with black goose neck tap on sink. If not, click on any picture and just keep moving right. You will see them all. Hey Kishore, Thank you for your feedback. Really appreciate it. I did take a look at the pictures you have posted. Your home looks very nice. Good on you, hope you are enjoying your new home. I will post some more questions if I need some help and inputs as and when I progress down the road to starting construction. Cheers, BrissyBloke Re: My new home in Capestone Mango Hill with Clarendon Wentw 39Jan 10, 2020 7:27 pm kishore RubyornotRuby Hi mate, How you going? I am planning to build Wentworth 35 design with some modifications. I just read your post and having a second thoughts about building with Clarendon Homes now. - Do you mind telling, how much extra you paid compared 5o your initial cost estimate? - ar3 you happy with the traditional facade? - how does current sapphire option compare against the one you had it in 2017? - did you have to do anything past handover and how much you spent? Hi, we paid quite a bit extra on the original house price. As mentioned in my post, it all depends on your choices. Tradional facade is alright, but not to my liking. The one they showed on website and other paper work didn't match up with final draft. We just left it as it was getting too late to get into things. I am not sure what is in the offering on current sapphire price. Your biggest spend will be kitchen, electrical and tiles. Try to get good bargains on them. Even if they say diamond package has everything included, don't trust them. Ask for exclusions first . post handof, yes we did have few issues but most of them are getting sorted. thanks mate - really appreciate it. You mind sharing some pictures of the Facade' You don't have to Re: My new home in Capestone Mango Hill with Clarendon Wentw 40Jan 10, 2020 7:41 pm RubyornotRuby kishore RubyornotRuby Hi mate, How you going? I am planning to build Wentworth 35 design with some modifications. I just read your post and having a second thoughts about building with Clarendon Homes now. - Do you mind telling, how much extra you paid compared 5o your initial cost estimate? - ar3 you happy with the traditional facade? - how does current sapphire option compare against the one you had it in 2017? - did you have to do anything past handover and how much you spent? Hi, we paid quite a bit extra on the original house price. As mentioned in my post, it all depends on your choices. Tradional facade is alright, but not to my liking. The one they showed on website and other paper work didn't match up with final draft. We just left it as it was getting too late to get into things. I am not sure what is in the offering on current sapphire price. Your biggest spend will be kitchen, electrical and tiles. Try to get good bargains on them. Even if they say diamond package has everything included, don't trust them. Ask for exclusions first . post handof, yes we did have few issues but most of them are getting sorted. thanks mate - really appreciate it. You mind sharing some pictures of the Facade' You don't have to Pics posted already in my post. Number 34 or 35 out of 45 pics if I remember correct . Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20152 I brought terry road box hill in June 2022 House was meant to be completed Nov 2023 That did not happen I had to chase them so much to the land Registration and… 0 2511 the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6731 |
