Browse Forums Building A New House Re: Henley Reserve - Cullen 45 .. Disorganised Tender ! 42Oct 26, 2017 4:16 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Henley Reserve - Cullen 45 .. Thinking of cancelling bui 45Nov 16, 2017 11:22 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Henley Reserve - Cullen 45 .. Build Cancelled ! 50Dec 18, 2017 5:34 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Henley Reserve - Cullen 45 .. Build Cancelled ! 57Feb 07, 2018 10:41 am baronx Exxie May I ask what sort of slab PD uses that turned you away? They use a waffle pod slab which is essentially hollow polystyrene boxes with a thin layer of concrete on top. The main difference is the raft is dug into the ground whereas a waffle sits on top of the site. Hi Baronx,Keen to know what's your next step? Any plan or builder decided? My tender is next week if things does not go well I will wash my hands as well with Henley. Also they are giving me P slab Raft re in forced .What your comment on this? Re: Henley Reserve - Cullen 45 .. Build Cancelled ! 58Feb 07, 2018 10:59 am did you do any custom customization apart from builder listed..henley seems to be very persistent with custom changes. Will be good to know.. due to no display house any where my worry areas are entry width with stairs, shower at ground level and butler pantry being small. planning to have 2 sliding doors for theater room which might give illusion house is small apart from that i love this design.. I did ask them to extend length 1.5 m which they declined for dining area but approved for alfresco Re: Henley Reserve - Cullen 45 .. Build Cancelled ! 59Feb 07, 2018 11:09 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Dverma,my lot is 20m wide and I needed guest bedroom downstairs ,so I did not convert the study in to guest rather added a guest bedroom with ensuite on the side of the side .relocated fridge to butler pantry and moved Sink and DW to the fridge are with Window.quite a lot of custom changes but got it approved 1 year ago they are not making any custom changes now. Re: Henley Reserve - Cullen 45 .. Build Cancelled ! 60Feb 07, 2018 11:19 am karthik Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Dverma,my lot is 20m wide and I needed guest bedroom downstairs ,so I did not convert the study in to guest rather added a guest bedroom with ensuite on the side of the side .relocated fridge to butler pantry and moved Sink and DW to the fridge are with Window.quite a lot of custom changes but got it approved 1 year ago they are not making any custom changes now. hi karthik, are you able to share your kitchen/bulter pantry photo to get an idea and also which facade you going with I choose ultima but again there is catch will be loosing .6m of bedroom area .. so again my thinking hat is on is your entry default floor plan 2740m or did you customize to widen that too. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10509 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17608 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 |
