Browse Forums Owner Builder Forum Re: Detailed sequence of trades and tasks for new owner buil 3Feb 03, 2018 4:53 pm Or this one is quite good too (and is freely available): http://www.tyrrells.com/LiteratureRetri ... ?ID=121391 Re: Detailed sequence of trades and tasks for new owner buil 4Apr 25, 2018 9:26 pm mcnugget15 Hi everyone Where can I get a detailed schedule of trades and tasks or detailed construction sequence for a typical brick house build? I've been able to located plenty of high level lists providing the general sequence of the trades however I looking for much more detail so as to ensure I don't accidentally miss a task and make a mistake. Thanks for your help sounds like you're out of your league .. by the sounds of this post you might be better off hiring a builder Re: Detailed sequence of trades and tasks for new owner buil 5Feb 05, 2019 7:12 am Im also have such a list if it exists, although I feel like Im going to have to do my own (best way to make it stick!). The Allan Staines book looks good, will give that a go (found some resources in from WA government, but they are a bit dated). Re: Detailed sequence of trades and tasks for new owner buil 6Feb 05, 2019 8:55 am Most books on building Instructions and details are being replace with new AEC 3D BIM software The book assumes One size fits all, great if your building the exact House, not so if you deviate from text/image also AS & codes change,etc,etc. Old books, Plans & Projects require AEC BIM Updating and It's a booming Industry Here are some other benefits of BIM 3D Software 1.Allows you to Visualise your build, Extract quants ( ie m, m2, m3 ) and Data Here's an Example of (15 year Old) outdated Architectural BIM Projects to do after handover (AEC BIM ) 2.Data and proofs. (Math/Data proofs are universal, everyone is on the same screen) 3. Sequencing, planning & Scheduling now plugs directly into google sheets. MS project is overkill (see Example) 4.Automate changes/updates, checking, costings and Optimisation thru scripts and python connections 5.Don't confuse architectural only BIM with Engineering BIM, the first gives you an image without Data and proofs, mainly used in marketing.It has evolved into the second and is used every day on site by clients, builders and tradies on mobile devices, The complete AEC BIM (Building Information Modelling) Process is Architectural->Engineering->Construction when specifying/using BIM Don't stop at architecture, if you do, you won't be getting the best results Here's an old example of 2S MS Project hth Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Detailed sequence of trades and tasks for new owner buil 7Feb 05, 2019 9:25 am Thanks SBG, A few questions about BIM: - If your designer doesnt support it, can you import a DWG and make it BIM ready? - For an OB, apart from costings, what are the major benefits? Ie. If the trades you trust / prefer dont use it, then whats the point? - Does the BIM acutally give you instructions / concepts? The benefit I see fro constructions books is more the concepts (ie. supporting loads, weatherpoffing) rather than specific instructions (put x here to stop y). - Lastly - whats the cost in converting a non BIM dwg to a BIM ready DWG? Re: Detailed sequence of trades and tasks for new owner buil 8Feb 05, 2019 10:32 am Howser Thanks SBG, A few questions about BIM: 1. - If your designer doesnt support it, can you import a DWG and make it BIM ready? 2. - For an OB, apart from costings, what are the major benefits? Ie. If the trades you trust / prefer dont use it, then whats the point? 3.- Does the BIM acutally give you instructions / concepts? The benefit I see fro constructions books is more the concepts (ie. supporting loads, weatherpoffing) rather than specific instructions (put x here to stop y). 4.- Lastly - whats the cost in converting a non BIM dwg to a BIM ready DWG? 1. If you are starting from scratch pick the right software as It costs Time & money to covert any 2D Vector to BIM 3D (Solid Modelling Kernel) into a reliable Format. I suggest if your starting a new project pick Parasolid based BIM, as the next software advancement to come is automated simulations 2.Find Builders & Trades that do..... I get requests everyday from builders/trades for Bim Data and Models on projects, I also receive Cr@p file translations from other Architectural BIM Software and asked to extract data and to do the engineering.The same applies to BIM design as with building a house, If you have sh!t geometry & foundations respectively ..then watch out.. The job becomes a nightmare 3.For Instructions/details I use exploded Iso views with labels and notes I have a static (thousand details) book on engineering/Construction/Simulations that I take on site along with an ipad The Interactive 3D view linked to data wins out hands down 4. Cost varies depending on design complexity, data/proofs,Stages, etc I will put up the roof framework/Details/Quants that a builder/carpenter requested yesterday, cost about $350-$400? because the brickwork changed. I have to remeasure,redesign & recalculate the roof Timbers & Cladding for exact ordering quants hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Detailed sequence of trades and tasks for new owner buil 9Feb 08, 2019 7:07 pm Howser Here's what to expect from a BIM Roof Model 2D plans, engineering details, layouts , notes , approximate quantities, cut length, data & 3D Model, etc Apologies for condensing 3 Pages into 1 page OT, The BIM Data can also be used, linked and transmitted to and from site throughout the build for checking,certification, etc More to follow hth Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9686 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23896 |
