Browse Forums Building A New House Re: Anyone building with wentworth 33 with Clarendon? 141Oct 29, 2017 4:54 pm Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 143Oct 29, 2017 5:23 pm Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 145Oct 31, 2017 1:02 pm Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 147Nov 01, 2017 9:20 am Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 148Jan 18, 2018 12:50 pm Hi Wentworth33, Since my tender didn’t include NBN package, I got below quote from Zurcorp for $982.28. - Install Micron 700 Series Home Hub Including: 1x Phone Module (8 Input), 1x Data Module (8 Input) & 1x TV Multi Switch. Run Free To Air Antenna Cable & 2 x Satellite Link Cables To Roof Space. We will be having 3 Data point(2 in living rooms+1 in bed room) and 4TV point (1 living+3bedrooms). Since I am not going to install home phone and foxtel, “home phone module & satellite link cables to roof space” may be unnecessary for us. Am I correct? Wondering if there will be more economical options..? Another question on Digital antenna. Z quoted me $683 for Digital antenna! I realise I can install them post handover with approx cost $200-300 for double storey house. So I am thinking to take out the Antenna from the quote. In order to install digital antenna, is there any specific requirement?? Eg. install tv splitter on roof space + single power point. Thank you in advance! Re: Anyone building with wentworth 33 with Clarendon? 149Jan 18, 2018 1:42 pm shp1126 Hi Wentworth33, Since my tender didn’t include NBN package, I got below quote from Zurcorp for $982.28. - Install Micron 700 Series Home Hub Including: 1x Phone Module (8 Input), 1x Data Module (8 Input) & 1x TV Multi Switch. Run Free To Air Antenna Cable & 2 x Satellite Link Cables To Roof Space. We will be having 3 Data point(2 in living rooms+1 in bed room) and 4TV point (1 living+3bedrooms). Since I am not going to install home phone and foxtel, “home phone module & satellite link cables to roof space” may be unnecessary for us. Am I correct? Wondering if there will be more economical options..? Another question on Digital antenna. Z quoted me $683 for Digital antenna! I realise I can install them post handover with approx cost $200-300 for double storey house. So I am thinking to take out the Antenna from the quote. In order to install digital antenna, is there any specific requirement?? Eg. install tv splitter on roof space + single power point. Thank you in advance! Best for you to get Z to install digital antenna and the NBN, even if it cost more. The antenna splitter is best to be put on the roof space, because it cost 200-250 to run a cable to put it in the garage (combine with NBN). For data point, data point can be used for phone as well. If you are not going to use phone, you only need 1 data point in a room for the TV or internet / modem. You can add the data point using netgear switch that vost abour $45-$80. For TV point, you just need to put it into a room where you want to have the TV. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 151May 23, 2018 10:48 pm Hi Wentworth 33, How are you going with your build? We had frames up already, bricks were delivered last week , maybe start brickworks next week. Everything is good so far. I would like to share some pictures Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Anyone building with wentworth 33 with Clarendon? 152May 24, 2018 11:27 pm Hi Jess98 My land will be registered on 6 June 2018. Once its registered, Clarendon said they will start it as soon as early August 2018. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 153Dec 05, 2019 4:55 pm Hello All, We have almost finalized Wentworth 35 with some minor modifications to the ground floor to add a shower to the powder room. I looked at some of the plans discussed here and liked the idea to make Master Bedroom bigger. BrisBuild, Wentworth33 - I believe you guys have completed the build and have moved in. We would love to have a look at your homes and how it looks and feels, if it is possible and not inconvenient to you. There are no Wentworth display in Qld, hence we are having a hard time visualizing the house. Cheers ! Re: Anyone building with wentworth 33 with Clarendon? 154Dec 05, 2019 6:09 pm BrissyBloke Hello All, We have almost finalized Wentworth 35 with some minor modifications to the ground floor to add a shower to the powder room. I looked at some of the plans discussed here and liked the idea to make Master Bedroom bigger. BrisBuild, Wentworth33 - I believe you guys have completed the build and have moved in. We would love to have a look at your homes and how it looks and feels, if it is possible and not inconvenient to you. There are no Wentworth display in Qld, hence we are having a hard time visualizing the house. Cheers ! Where are you based ? My wentworth 33 is 80% modified. example : I flip the ground floor horizontally starting from the garage to kitchen. I also made a grand alfresco and huge changes in Bed 1, 2, 4, family room and main bathroom. I also swap study and media room. I dont think mine is good example for you. If you are looking for closes design to wentworth 35, you need to go to Parklea, Clarendon display home (Sydney). Check Madison design. only different by Stairs position and room size. Hope this helps. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Anyone building with wentworth 33 with Clarendon? 155Dec 05, 2019 8:02 pm wentworth33 BrissyBloke Hello All, We have almost finalized Wentworth 35 with some minor modifications to the ground floor to add a shower to the powder room. I looked at some of the plans discussed here and liked the idea to make Master Bedroom bigger. BrisBuild, Wentworth33 - I believe you guys have completed the build and have moved in. We would love to have a look at your homes and how it looks and feels, if it is possible and not inconvenient to you. There are no Wentworth display in Qld, hence we are having a hard time visualizing the house. Cheers ! Where are you based ? My wentworth 33 is 80% modified. example : I flip the ground floor horizontally starting from the garage to kitchen. I also made a grand alfresco and huge changes in Bed 1, 2, 4, family room and main bathroom. I also swap study and media room. I dont think mine is good example for you. If you are looking for closes design to wentworth 35, you need to go to Parklea, Clarendon display home (Sydney). Check Madison design. only different by Stairs position and room size. Hope this helps. Thank you for your response Wentworth33. I am located in Brisbane. Sydney display home would be too far for me. Yes, that sounds like a very modified plan. Which city is your house located ? Re: Anyone building with wentworth 33 with Clarendon? 156Dec 06, 2019 4:14 pm BrissyBloke wentworth33 BrissyBloke Hello All, We have almost finalized Wentworth 35 with some minor modifications to the ground floor to add a shower to the powder room. I looked at some of the plans discussed here and liked the idea to make Master Bedroom bigger. BrisBuild, Wentworth33 - I believe you guys have completed the build and have moved in. We would love to have a look at your homes and how it looks and feels, if it is possible and not inconvenient to you. There are no Wentworth display in Qld, hence we are having a hard time visualizing the house. Cheers ! Where are you based ? My wentworth 33 is 80% modified. example : I flip the ground floor horizontally starting from the garage to kitchen. I also made a grand alfresco and huge changes in Bed 1, 2, 4, family room and main bathroom. I also swap study and media room. I dont think mine is good example for you. If you are looking for closes design to wentworth 35, you need to go to Parklea, Clarendon display home (Sydney). Check Madison design. only different by Stairs position and room size. Hope this helps. Thank you for your response Wentworth33. I am located in Brisbane. Sydney display home would be too far for me. Yes, that sounds like a very modified plan. Which city is your house located ? I am in Sydney. I dont think you can find Wentworth 35 design in any display homes. Your best bet is to see something similar design like Madison and Sheridan or Waterside. These design are close to Wentworth design. Hope this helps Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6778 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7902 Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 24884 |
