Browse Forums Building A New House Re: Single story vs double story 11Jan 10, 2018 8:12 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Single story vs double story 18Jan 11, 2018 4:03 am Brenton41 sparrowsnest By going double story you add cost straight away just in the extra materials for load bearing walls etc when I looked a couple of years ago it was $20k plus just for that. It’s definitely cheaper per m2 to build single story if you’ve got the land space for it. Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Cheers for the feedback on that. We can achieve what we want in single story which is a good thing. Can’t shake the idea of a double story but will keep working on the floor plans and get something sorted I wanted an open plan double story with voids- I wouldn’t even look at a floor plan without voids. After a recent sickness in my house (and just daily life really!) i am 12 months post handover and I’d turn the clock back if I could and build a single level! What I would say is think about the things you can’t live without- things that can’t easily be upgraded down the track... if you have your heart set on a few of these things, think about whether there are a few other not so important items to trade off. For us, the staircase was important, so we simply have a mortgage that’s a bit bigger than it otherwise would have been, but we are still being financially responsible- but we also have the staircase I couldn’t do without. Having said that , these ‘must haves’ quickly add up when they are individually expensive. Just don’t discount a single level home because you’ve always had a double in mind. I would almost say I went into the admin/shopping stage blinded by what I thought I had always wanted. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Single story vs double story 19Jan 11, 2018 7:58 am MrsJM Brenton41 sparrowsnest By going double story you add cost straight away just in the extra materials for load bearing walls etc when I looked a couple of years ago it was $20k plus just for that. It’s definitely cheaper per m2 to build single story if you’ve got the land space for it. Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Cheers for the feedback on that. We can achieve what we want in single story which is a good thing. Can’t shake the idea of a double story but will keep working on the floor plans and get something sorted I wanted an open plan double story with voids- I wouldn’t even look at a floor plan without voids. After a recent sickness in my house (and just daily life really!) i am 12 months post handover and I’d turn the clock back if I could and build a single level! What I would say is think about the things you can’t live without- things that can’t easily be upgraded down the track... if you have your heart set on a few of these things, think about whether there are a few other not so important items to trade off. For us, the staircase was important, so we simply have a mortgage that’s a bit bigger than it otherwise would have been, but we are still being financially responsible- but we also have the staircase I couldn’t do without. Having said that , these ‘must haves’ quickly add up when they are individually expensive. Just don’t discount a single level home because you’ve always had a double in mind. I would almost say I went into the admin/shopping stage blinded by what I thought I had always wanted. I think we are nearly spot on the same with that mindset. We have just sold our first home that we built without a Metricon which was a pretty entry level single story. We had it in our mind that going double story would be big and grand as we want to stay in this house for the next 10 years or so. The good thing is our budget is good so we can build a great single story home and have all the bells and whistles or go for the double story but I just didn’t want the original quote to blow over another 10k from where we are already at. Need to make that decision now and make sure we don’t regret doing it. Re: Single story vs double story 20Jan 13, 2018 2:22 pm Just my 2 cents worth... Your block is quite big compared to most and you will find that there is a minimum percentage of land that you can't build on (I suppose this depends the Council regulations you are dealing with too) having said that you can build a single story grant home/mansion with all the bells and whistles (like you said) and have decent yard. However, how close are your neighbours? Are you in a new estate (if so you can probably jump onto the local council site Application Tracker (or equivalent) and check what your neighbours will be building next to you. I don't think I could stand having a double story next to me if I went single (that's just me though). Another reason as stated by one of the members above is the view: if a second story would take advantage of that and increase the value of your home and can't be out built by other homes around you over time, then the outlay now will be beneficial later. Stairs? We were quoted $14000 for open treads and glass around the void. Gorgeous, yes, did we do it? No. You can always put glass in later and if you have kids and pets be prepared to wipe the smears very regularly. And the obvious 'up and down'. We have 18 stairs straight up and by the 15th time it kind of gets tiring. There are some stunning single story homes you can really add some oomph instead of having to pay for extras for two story as Structural Guy stated (scaffold, barricades and safety items) which can amount to $20-$25K. You've been through it before so you should be right with the process. Good luck! Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4140 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8572 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8592 |
