Browse Forums Buying Land Re: NBN pit & pipe 7Jan 02, 2018 6:28 pm Developer needs to do the AFR (application for reticulation), it is required by federal law but the issue is no agency enforces it. It should be a requirement before titles are issued, but the various government departments have been slow to act & amend approval process. Go back to developer with the information in link below & hopefully they will comply. if they don't you have two options seek legal advice or form a body corporate with other owners of development to complete the AFR. I'm having this issue now myself, basically getting no responses from seller ATM. I gather they know this policy is not enforced & hopes I will eventually stop bothering him, I will most likely seek legal advice if I get no results with real estate agent. https://www.telstra.com.au/smart-community# Re: NBN pit & pipe 8Jan 02, 2018 9:37 pm JenBarber Thank you, I didn’t realise all new homes get NBN lead ins, it makes sense though considering the roll out. I’m assuming then that the lead in cost is charged to you? The IT crowd is great, as is Jen 👍🏼 Yes telstra said it is legally the developers responsibility but if they dont put it in then the responsibility falls on the purchaser of the land 😠 Very annoying they are not following up on there own legislation. Fortunately we haven't settled on our land yet so we have a bit of power. Re: NBN pit & pipe 9Jan 02, 2018 9:39 pm Sethor Developer needs to do the AFR (application for reticulation), it is required by federal law but the issue is no agency enforces it. It should be a requirement before titles are issued, but the various government departments have been slow to act & amend approval process. Go back to developer with the information in link below & hopefully they will comply. if they don't you have two options seek legal advice or form a body corporate with other owners of development to complete the AFR. I'm having this issue now myself, basically getting no responses from seller ATM. I gather they know this policy is not enforced & hopes I will eventually stop bothering him, I will most likely seek legal advice if I get no results with real estate agent. https://www.telstra.com.au/smart-community# Thanks, I found this link really helpful as it quotes the legislation and was written by a lawyer that specialises in telecommunications. Hope it helps you with your battle too. https://www.google.com.au/amp/s/amp.the ... velopments Re: NBN pit & pipe 10Oct 09, 2018 1:10 pm Hi guys, I work for a builder in Perth and we come across this often and it is absolutely ridiculous that it isn't a condition from the WA Planning Commission, I have tried several times to raise it with them but seem to get fobbed off, I have recently contacted the Planning minister and of yet haven't received a response but am going to follow up. The developer of these blocks think its a builders responsibility for this and as previously posted is is most definitely not but we seem to get the blame for it most of the time, if the buyer of the land hasn't written up the offer when they come to us we tell them to write the following clause as a special condition. "Communications infrastructure to be completed by developer as per the federal government communications act." Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9526 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19952 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7297 |
