Browse Forums Pools & Spas Re: Fiberglass Pool Bleaching under the water line 10Dec 23, 2017 9:19 am By the way, we have never owned a pool before and last summer was getting what looked like yelloe algae so the pool shop we were using at the time (have since changed) suggested a shock with chlorine so we did with granulated chlorine and our levels went up to 20ppm - so I guess maybe ours is from that but nobody told me you shouldn't do it - I believed the pool shop guy having no idea about pools! I am going to get some sand paper at the poster above suggested too and try that even just on the higher parts of the pool wall see if that makes a difference. Interested to hear too which chlorinator setup you have? We have a Astral Viron Equilibirum chlorinator with variable speed pump. thanks. Re: Fiberglass Pool Bleaching under the water line 11Dec 23, 2017 4:45 pm take a wander over to TFP and find out how much you and the pool shop dont know https://www.troublefreepool.com/content ... e?tabid=40 Re: Fiberglass Pool Bleaching under the water line 12Jan 02, 2018 6:41 pm Thanks aussie's - but what exactly do you suggest I look at on that site? I have since found out that it is a manufacturing fault most likely, with a batch of gelcoats around the same time our pool was put in, but the pool companies are using too much chlorine as an excuse not to uphold their guarantee! So basically we are stuck with a fadiing pool after only 2yrs and the pool company won't own up! I will be investigating further and contact Consumer Affairs! I would be very interested to hear from anybody else please with this problem. Please feel free to msg me. thanks. Re: Fiberglass Pool Bleaching under the water line 13Feb 14, 2018 1:42 pm Hi dons80 - do you have any further update on your situation please? We have had no luck with ours and contemplating whether it is worth the fight with the pool company or just put up with it looking so awful. Re: Fiberglass Pool Bleaching under the water line 14Feb 15, 2018 5:29 pm Tried fiberglass polish with an electric buffer it was ok but will need to go over it again problem is you need to have the water very low which is costing when refilling and extra chemicals might try a light wet and dry sand paper as well next time;f Re: Fiberglass Pool Bleaching under the water line 16Mar 19, 2018 7:15 pm Does it look something like this . It is a classic case of over chlorinating for a long period of time . I went and looked at a pool last week only 15month old . It isn’t as bad as the one in this photo but has first signs of over chlorinating. Customer stated his pool guy was maintaining his pool so it must be correct . A test showed chlorine level off the scale . Speaking with people in the industry it is a common problem at the moment . Even concrete pools are getting damaged finishes for the same reason . We are now using automation which will only turn the chlorinator on when level drops . It’s expensive now but will be the norm in 5-10 years . Then this problem will be a thing of the past . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Fiberglass Pool Bleaching under the water line 17Mar 19, 2018 7:54 pm Hi, thanks for your photo. Mine isn't as bad as this one but without draining all the water, you never know. You seemed to have seen a lot of similar issues with over chlorination. Rather than the cosmetic issue, does it cause any other issues? Is it still safe to swim? Some parts of my pool wall became a bit chalky, meaning I can move he white stuff with my hand. Thanks in advance Re: Fiberglass Pool Bleaching under the water line 18Mar 19, 2018 7:59 pm JBP Hi, thanks for your photo. Mine isn't as bad as this one but without draining all the water, you never know. You seemed to have seen a lot of similar issues with over chlorination. Rather than the cosmetic issue, does it cause any other issues? Is it still safe to swim? Some parts of my pool wall became a bit chalky, meaning I can move he white stuff with my hand. Thanks in advance Perfectly safe to swim in . When water is drained it looks 50 times worse . Re: Fiberglass Pool Bleaching under the water line 20May 31, 2018 5:55 pm i am seeing terms such as "chlorine too high" "chlorine balanced" "chlorine off the scale" the fc must be in relationship to the cya level so 20ppm fc would be maximum for a 50ppm cya level and 20ppm fc could bleach liner below 50ppm cya a fas dpd chlorine test does not have a maximum limit so there is no off the scale how about some accurate numbers from a quality test kit Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20184 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11760 4 10822 |
