Browse Forums Building A New House Re: KDR Metricon Liberty - Hampshire 45 QLD 1694Dec 18, 2017 6:18 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1695Dec 18, 2017 6:21 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1697Dec 18, 2017 7:59 am Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1698Dec 18, 2017 8:10 am nomnomnom heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. I originally had stacker and sliding door rebates but these were eventually cancelled by M when I told them I would be doing my own hardwood flooring post handover. If you’re like me and are doing hardwood flooring, they can’t rebate the doors because your floor will sit 40mm above slab level. One point to note is try to have the same type of doors. Ie Stacker/stacker, or sliding/sliding. Not Stacker/sliding. What I found was that the finished floor level of the doors varies for a stacker vs a sliding door. A stacker will sit 50mm above slab and a sliding will sit 40mm. If this is the case you need to change your doors or make sure you tell your site Manager to tell the carpenter to lift and pack under the sliding door an extra 10mm or else it’s outside of Building code to have two different finished floor levels. I am getting 19mm solid timber that will be a direct stick to the slab. When I got M to do the slider door rebate I advised that of the 19mm and they design the rebate to match the floorboards. I hope it turns out nice and flushed. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1699Dec 18, 2017 12:20 pm heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Thanks, I'm glad you enjoyed the read =) As for your question, yes I got my sliding doors rebated into the slab. Wasn't any issues at all. Which state are you in? Re: KDR Metricon Liberty - Hampshire 45 QLD 1700Dec 18, 2017 12:23 pm nomnomnom Dulie, Great job on the deck there! Looks amazing. Did you use Merbau? What’s the expected maintenance of the deck too? My landscaper is encouraging me to consider Modwood as it’s low maintenance but I’m not sure about it. Thanks. Yes I went with 140 x 19 Merbau. I'm using Sikkens for the staining/protection. It has a yearly re-coat recommendation. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37085 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19075 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13437 |
