Browse Forums Building A New House Re: Metricon Liberty 45 (Turramurra) 384Dec 07, 2017 8:55 pm Building a modified Madison 39 with Clarendon Homes in Tennyson homeone link: viewtopic.php?f=31&t=79106 Blog Link: https://minandb.wordpress.com/ Re: Metricon Liberty 45 (Turramurra) 385Dec 07, 2017 8:59 pm Building with Metricon Liberty 45 Vogue on Sydney Northern Beaches https://forum.homeone.com.au/viewtopic.php?f=31&t=88438 Metricon Liberty 45 (Turramurra) 386Dec 08, 2017 1:18 am NthHome Kandi Hi All We have received our final plans today, we need to get back to them ASAP. Can you all please check and give your comments. If you can find any errors/issues or improvement can be made. please post your comments kindly. How do i post the plan here? Email me them My suggestions are 1) Widen garage and the garage doors. Esp if you have an SUV and your block can allow it. 6m door would be good. 2) I’d put your timber feature doors on the sitting room not the guest bedroom. They have large glass panels and if someone’s sleeping and you turn on the hallway light.... 3) Ask to make the internal door to the garage a solid door. The hollow ones they provide are crappy and weak. I wish I’d done it. 4) Make rear garage door bigger. Eg 1200. Esp if you need to get stuff thru to the yard later on. 5) Change door on WIL near laundry to Cavity slider. Seems a little tight. 6) Have M pour the slab under the porch with your main slab. Much stronger and they will (should) Pier it too. 7) The doors to the Butlers pantry are uneven. You might have a good reason for that but I’d even it up. I’d insulate the garage walls and roof. There is an argument that it is wasted money since the garage door is so big that you lose the benefit but I still feel it is worth it. 9) Have you got enough insulation for your area? Eg walls are only r1.5? I put r2.5 in my walls and r4.0 in ceiling. And that’s for Sydney. Google “recommended insulation for (where you live)” to see the government recommendation. 10) Do you have roof sarking? 11) Consider the location of your water control taps for the shower. They all seem to be centrally placed under the shower head so your arm gets wet when you turn tap on. 12) consider external ducting for laundry if you’re not having a heat pump dryer. 13) consider increasing your main shower area. eg anything 900x 900 is ok but a little tight. 1000x1000 is better. 14) Consider making the Door to the main ensuite a single fixed 1020 door vs having 2 cavities. This will increase wall space for you to fit a heated towel rail behind it. I changed mine from 2 cavity sliders to a single fixed and am happy with how it looks. House looks great otherwise. It’s going to be awesome. Love the layout. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Metricon Liberty 45 (Turramurra) 390Dec 08, 2017 6:21 pm nomnomnom NthHome Kandi Hi All We have received our final plans today, we need to get back to them ASAP. Can you all please check and give your comments. If you can find any errors/issues or improvement can be made. please post your comments kindly. How do i post the plan here? Email me them My suggestions are 1) Widen garage and the garage doors. Esp if you have an SUV and your block can allow it. 6m door would be good. 2) I’d put your timber feature doors on the sitting room not the guest bedroom. They have large glass panels and if someone’s sleeping and you turn on the hallway light.... 3) Ask to make the internal door to the garage a solid door. The hollow ones they provide are crappy and weak. I wish I’d done it. 4) Make rear garage door bigger. Eg 1200. Esp if you need to get stuff thru to the yard later on. 5) Change door on WIL near laundry to Cavity slider. Seems a little tight. 6) Have M pour the slab under the porch with your main slab. Much stronger and they will (should) Pier it too. 7) The doors to the Butlers pantry are uneven. You might have a good reason for that but I’d even it up. I’d insulate the garage walls and roof. There is an argument that it is wasted money since the garage door is so big that you lose the benefit but I still feel it is worth it. 9) Have you got enough insulation for your area? Eg walls are only r1.5? I put r2.5 in my walls and r4.0 in ceiling. And that’s for Sydney. Google “recommended insulation for (where you live)” to see the government recommendation. 10) Do you have roof sarking? 11) Consider the location of your water control taps for the shower. They all seem to be centrally placed under the shower head so your arm gets wet when you turn tap on. 12) consider external ducting for laundry if you’re not having a heat pump dryer. 13) consider increasing your main shower area. eg anything 900x 900 is ok but a little tight. 1000x1000 is better. 14) Consider making the Door to the main ensuite a single fixed 1020 door vs having 2 cavities. This will increase wall space for you to fit a heated towel rail behind it. I changed mine from 2 cavity sliders to a single fixed and am happy with how it looks. House looks great otherwise. It’s going to be awe some. Love the layout. Thank you so much for your comments. No6. I thought the porch concrete is included as part of the house.? does it says some where its not included? Re: Metricon Liberty 45 (Turramurra) 391Dec 08, 2017 9:31 pm Great news NthHome, enjoy your brand new home Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 (Turramurra) 395Dec 11, 2017 7:47 pm nomnomnom NthHome Kandi Hi All We have received our final plans today, we need to get back to them ASAP. Can you all please check and give your comments. If you can find any errors/issues or improvement can be made. please post your comments kindly. How do i post the plan here? Email me them My suggestions are 1) Widen garage and the garage doors. Esp if you have an SUV and your block can allow it. 6m door would be good. 2) I’d put your timber feature doors on the sitting room not the guest bedroom. They have large glass panels and if someone’s sleeping and you turn on the hallway light.... 3) Ask to make the internal door to the garage a solid door. The hollow ones they provide are crappy and weak. I wish I’d done it. 4) Make rear garage door bigger. Eg 1200. Esp if you need to get stuff thru to the yard later on. 5) Change door on WIL near laundry to Cavity slider. Seems a little tight. 6) Have M pour the slab under the porch with your main slab. Much stronger and they will (should) Pier it too. 7) The doors to the Butlers pantry are uneven. You might have a good reason for that but I’d even it up. I’d insulate the garage walls and roof. There is an argument that it is wasted money since the garage door is so big that you lose the benefit but I still feel it is worth it. 9) Have you got enough insulation for your area? Eg walls are only r1.5? I put r2.5 in my walls and r4.0 in ceiling. And that’s for Sydney. Google “recommended insulation for (where you live)” to see the government recommendation. 10) Do you have roof sarking? 11) Consider the location of your water control taps for the shower. They all seem to be centrally placed under the shower head so your arm gets wet when you turn tap on. 12) consider external ducting for laundry if you’re not having a heat pump dryer. 13) consider increasing your main shower area. eg anything 900x 900 is ok but a little tight. 1000x1000 is better. 14) Consider making the Door to the main ensuite a single fixed 1020 door vs having 2 cavities. This will increase wall space for you to fit a heated towel rail behind it. I changed mine from 2 cavity sliders to a single fixed and am happy with how it looks. House looks great otherwise. It’s going to be awesome. Love the layout. Hi Nom Thanks for reviewing the plan. You were right. portico concrete was missing. We have checked our inclusion list and it was included. So Drafting is amending our plan. The door between the kitchen and butler should not be there. We have requested to delete it. We have also requested to upgrade the walls to R2.5 for and 4 for Celling. how much this costed you. yes we have sarking. in our inclusion sisalation "wall wrap" to single story is included. did you had this one. Thanks Kandi Re: Metricon Liberty 45 (Turramurra) 396Dec 12, 2017 5:51 am Congrats NthHome When is moving day? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Metricon Liberty 45 (Turramurra) 397Dec 12, 2017 8:06 am Renman Congrats NthHome When is moving day? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Either this weekend or next. Just waiting on removalist to confirm Re: Metricon Liberty 45 (Turramurra) 398Dec 12, 2017 4:34 pm NthHome Renman Congrats NthHome When is moving day? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Either this weekend or next. Just waiting on removalist to confirm Congratulations! Awesome news. Can I ask who you’ll be using for Tv Antenna instal? I called Jim’s antennae and it’s $380 for a double storey home. Wondering if you’ve had a better quote? Cheers Nomnomnom Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: Metricon Liberty 45 (Turramurra) 399Dec 12, 2017 4:36 pm nomnomnom NthHome Renman Congrats NthHome When is moving day? My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Either this weekend or next. Just waiting on removalist to confirm Congratulations! Awesome news. Can I ask who you’ll be using for Tv Antenna instal? I called Jim’s antennae and it’s $380 for a double storey home. Wondering if you’ve had a better quote? Cheers Nomnomnom At this stage not sure. 380 seems reasonable though. I actually thought it’d be more Re: Metricon Liberty 45 (Turramurra) 400Dec 12, 2017 11:36 pm Congratulations! Metricon Glendale 38 - https://forum.homeone.com.au/viewtopic.php?f=1&t=88854 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12869 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9745 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19800 |
