Browse Forums Building A New House Re: First Build with Summit Perth WA 10Dec 07, 2017 8:30 pm Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Build with Summit Perth WA 14Dec 07, 2017 9:45 pm Our private certifications are generally turned around within 24 hours unless there is a missing document that has been missed / forgotten about. This could cause potential delays in obtaining the required info, but you are correct in believing that the certifications should have a quick turn-around! Fingers crossed you can get it down! Where abouts are you building? Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Build with Summit Perth WA 15Dec 07, 2017 11:17 pm nicolac34 Summitlovin nicolac34 Exciting if you get your slab before Christmas! Where abouts are you building? I'll look forward to following your progress, we are probably a month behind you It would be! I want to use the Xmas break in my favour to cure the slab rather than it be wasted time. I’m anxiously waiting for updates! Are you building with Summit also? No we are Aveling - our development is pretty tight, only 4 builders to choose from! wow, can't say i have heard of a developer stipulating what builder you can use. They must've had some sort agreement with the companies which is making them some serious $$$. I saw your pre-start selections-i think your front facade will be similiar colour wise to mine. If my slab doesn't go down until Jan looks like our builds will start around the same time. So exciting! Re: First Build with Summit Perth WA 16Dec 07, 2017 11:23 pm I believe it's a similar system like that over east, however it's the first time I've heard it being done here. I feel like we've done a job or 2 in that estate though and I'm not from any of the companies mentioned on their brochures. Might have a look into it tomorrow Find my build thread here: https://forum.homeone.com.au/viewtopic.php?t=88694&f=31&p=1729530#p1729530 Re: First Build with Summit Perth WA 17Dec 07, 2017 11:27 pm just_a_draftee Our private certifications are generally turned around within 24 hours unless there is a missing document that has been missed / forgotten about. This could cause potential delays in obtaining the required info, but you are correct in believing that the certifications should have a quick turn-around! Fingers crossed you can get it down! Where abouts are you building? Good to know, when i have an update tomorrow i will be asking the question then. I am assuming the engineering/site surveying delay caused this all to be held up. I even volunteered to drop my building application off to the shire to save time but with postage but this was politely declined. I'm going to be building in Piara Waters. Re: First Build with Summit Perth WA 18Dec 08, 2017 12:44 pm Love your design, the Alkira display home in Calleya is an amazing house. We also chose Glenn as our design consultant and found him to be brilliant. The small suggestions and changes he made improved our house no end. Good luck with the build! Re: First Build with Summit Perth WA 19Dec 08, 2017 5:27 pm CalleyaBuild Love your design, the Alkira display home in Calleya is an amazing house. We also chose Glenn as our design consultant and found him to be brilliant. The small suggestions and changes he made improved our house no end. Good luck with the build! Thank you 😊 the alkira was the first home I walked into and was the design that stood out for me out of many houses. Glenn gave me so much info up front and even now is assisting me with little bits of info. Re: First Build with Summit Perth WA 20Dec 08, 2017 5:30 pm Haha it was my favorite too but sadly not my wife's! The theater room at the back is spectacular imo. Hopefully you will get Jamie as a site supervisor too, he's really good hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 4587 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27716 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17601 |
