Browse Forums Building A New House Re: Wisdom Majestic 38 - Swapping Living and Alfresco 17Dec 07, 2017 5:39 am I think the swap in the way your proposing will be really open and lovely. If you run the kitchen cabinetry to the wall and then have the bifolds from the kitchen meeting with the bifolds from the leisure and then windows from the leisure out to the pool I think you will achieve a really open coastal feel. Such hard decisions! Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Wisdom Majestic 38 - Swapping Living and Alfresco 18Dec 07, 2017 6:36 am stevezau we built majestic and removing the pillar between the bifold will require a structural steam beam to be added so it can be done but we were being quoted appx $12k Have you thought about mirroring the entire floor Plan? Would the pool then fit behind the alfresco which would be on the right and you still have that side yard access which would now be on the left? Not sure if that would work for you but just a suggestion, we mirrored our majestic layout for solar orientation. Where’s north? majestic35.weebly.com Re: Wisdom Majestic 38 - Swapping Living and Alfresco 19Dec 07, 2017 6:53 am Rocchet @stevezau we built majestic and removing the pillar between the bifold will require a structural steam beam to be added so it can be done but we were being quoted appx $12k Have you thought about mirroring the entire floor Plan? Would the pool then fit behind the alfresco which would be on the right and you still have that side yard access which would now be on the left? Not sure if that would work for you but just a suggestion, we mirrored our majestic layout for solar orientation. Where’s north? We looked at mirroring the whole setup but we wouldn't get the sun on the left hand side yard. If standing at the back, facing the back fence. It faces north, maybe more like a little north east. So the sun comes from the right to left over the backyard. Wisdom suggested the best solar orientation was the way it's setup on the image I posted. Not sure if that's correct? Re: Wisdom Majestic 38 - Swapping Living and Alfresco 20Dec 07, 2017 6:56 am sparrowsnest I think the swap in the way your proposing will be really open and lovely. If you run the kitchen cabinetry to the wall and then have the bifolds from the kitchen meeting with the bifolds from the leisure and then windows from the leisure out to the pool I think you will achieve a really open coastal feel. Such hard decisions! Building our first custom dream home. https://r.tapatalk.com/shareLink?share_ ... are_type=t Yeah it might look ok but I have a gut feeling that the existing layout is much nicer, separate kitchen and living area. Stuck.. I need to compromise somewhere but it's so damn hard to choose I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10207 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1707 Hi, guys! If you've built with Wisdom Homes, would you mind sharing images of your front facades once they're all rendered? I'm considering signing up with them for a wide… 0 14065 |
