Browse Forums Building A New House Re: North Shore Newhaven (Sydney) 122Nov 30, 2017 9:04 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 124Dec 02, 2017 4:20 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 127Dec 02, 2017 10:57 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 129Dec 03, 2017 7:42 am Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 131Dec 03, 2017 10:08 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 134Dec 05, 2017 10:15 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 135Dec 05, 2017 10:30 pm Vet nomnomnom Love your floor boards did you get them done by M? Hi Vet, I’m doing the flooring with my own contractor. Was meant to be done post handover but they’re so late on my build they’ve agreed to let me contractor on site early. I bought 80mm x 19 mm spotted gum hardwood flooring in select grade. I am having these boards installed over 19mm hardwood battens which are anchored into the slab using concrete pins sorta like dynabolts. The problem my floorer found was that the upper slab was uneven by up to 20mm in some spots in the same room. Max tolerance under building code is 4mm in any 2 m distance and 10 mm for an entire room. in one section there was a difference of 15 mm across 2 m! What was happening was that my floorer was having to plane back the batten from 19mm to say 9mm so that the floor would be level in some places. When he nailed the batten to the slab it split. That’s when he told me he couldn’t guarantee the floor. So I told the CM and SM and asked why the slab wasn’t fixed? So I had to find a contractor to grind the slab and then pour levelling compound. This will allow me to lay 12mm plywood and then install the floorboards on that. Plywood is generally the preferred substrate to install hardwood floors on but it’s more expensive than battens. If you choose the more expensive 130mm x 19mm boards, they will have to use plywood. You might already know all this, but thought I’d explain it all justin case anyone else is reading and wondering. Given all the hassel with getting the slab level, this is why M don’t do real hardwood flooring. Plus they have to put expansion cork in at certain intervals and people don’t like that so the try and get it deleted but the floor can buckle so they had those issues too. That’s why they just sell engineered flooring. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 136Dec 06, 2017 3:48 pm Thanks Norm for the detail reply, very informative. I am not looking forward to the stress that is associated with building. Having uneven floors would have taken you over the edge!! I haven't yet done my research when it comes to floors. I just hate that we pay for the floors and we don't get any credit if we don't use their flooring. Did it end up being cheaper for you getting it done externally? Can you recommend a company for me to go check out? Re: North Shore Newhaven (Sydney) 137Dec 06, 2017 6:09 pm Vet Thanks Norm for the detail reply, very informative. I am not looking forward to the stress that is associated with building. Having uneven floors would have taken you over the edge!! I haven't yet done my research when it comes to floors. I just hate that we pay for the floors and we don't get any credit if we don't use their flooring. Did it end up being cheaper for you getting it done externally? Can you recommend a company for me to go check out? What? They make you pay for the floor and don’t give you a credit if it’s not being used? I’d have a chat to my sales agent and call their bluff. Lots of other companies like Rawson, Eden Brae and Clarendon wouldn’t do that. You can buy flooring from Abbey Timbers or EvaGroup. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 North Shore Newhaven (Sydney) 138Dec 13, 2017 11:03 pm flooring all laid. sanding and putty today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lacquering and driveway cut tomorrow. Also put in TV antenna today. Ended up being $650 which got me.... * Aust made Antenna with 5 yr warranty * Colorbond roof mount. Designed to go with colorbond roofs so can use existing holes and screws and no need to drill extra holes. * 4 way coaxial splitter * Signal booster (essential since I have 4 Co ax points in the house and the signal deteriorates with each point. I can highly recommend Sukamal from Jim’s. He spent a good 4 hours on the job installing the antenna, installing the gear and checking the signal at each point. On the last co axial point tested, it was dead! No signal. He takes off the cover plate and what do we see??.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes that’s right! Vaccaro had installed the co axial cable but hadn’t of bothered to connect it to the face plate. ggrrrr. Luckily he had the crimping tool to do the job and free of charge. He connects the signal checker again and still no signal. He says he will climb back into the roof and replace the signal splitter on the off chance that it is faulty. He said he doubts that it is the case since it hasn’t happened ever. Does his thing. Comes back out of roof sweating it...tests the signal! Bam! It works! So what are the chances that both the cable wasn’t connected and the splitter was faulty! Anyway, I’m just glad it all worked out and Really happy with the work ethic of Sukamal in spending such a long time to make sure the job was done right the first time and for a discounted price too. I only wish more tradies were like that. Here’s is a pic of the splitter and signal amplifier in the roof. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Call Sukamal for all your antenna needs. I can not recommend him highly enough. +61 452 584 160 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 139Dec 13, 2017 11:36 pm I’ve had some discussions with people asking about overhead cabinetry height in the kitchen. Just to explain, the default design by Metricon is that if you have a kitchen window as a back splash, then the overhead cabinetry will hang down about 20mm past the top window frame. That is to say that anyone standing outside will see the back of your cabinets! So unless that’s the look you’re going for, You need to specify during your Kitchen Culture appointment that you want the overhead cupboards raised so they are not visible from the outside. It will then be noted in your paperwork. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One other important reason to do this is because if M don’t install the window straight according to building standard, like they have at mine, then it is quite easy for them to access the window internally and fix it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Here you can see the window is 7mm bellied using a 2m level. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 North Shore Newhaven (Sydney) 140Dec 14, 2017 5:49 am Yikes that new floor looks Devine! How progressing well. Our kitchen feature window also bows in the middle a little bit due the long window (3.7m). Orpheus Building the Metricon Glendale 38|Sydney Hi i am looking to buy an investment near by North Rothbury. How is this area? is there schools inside this estate? please advice good builders around that area to buy… 0 3021 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18198 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22813 |
