Browse Forums Building A New House Re: KDR Metricon Liberty - Hampshire 45 QLD 1682Dec 02, 2017 9:36 pm dulie 6 weeks in the making. I decided to give decking a go. Finally finished today. Quite happy with the results =D Some progress, before and after pics. Gotta let it weather for a few weeks before I oil it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?t=88952 Re: KDR Metricon Liberty - Hampshire 45 QLD 1683Dec 02, 2017 9:40 pm dulie 6 weeks in the making. I decided to give decking a go. Finally finished today. Quite happy with the results =D Some progress, before and after pics. Gotta let it weather for a few weeks before I oil it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oooh wow that’s looks amazing . You definitely got my style. Your so talented. viewtopic.php?t=86597 Re: KDR Metricon Liberty - Hampshire 45 QLD 1685Dec 02, 2017 10:06 pm Dude Looks like the professional did it for you. Great job. Looks like I’ll be flying you down for the decking and Orph down for the lighting at my place. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1686Dec 02, 2017 10:08 pm Renman Dude Looks like the professional did it for you. Great job. Looks like I’ll be flying you down for the decking and Orph down for the lighting at my place. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Me too Ren. These guys are pro at what they do. viewtopic.php?t=86597 Re: KDR Metricon Liberty - Hampshire 45 QLD 1687Dec 03, 2017 5:08 am dulie 6 weeks in the making. I decided to give decking a go. Finally finished today. Quite happy with the results =D Some progress, before and after pics. Gotta let it weather for a few weeks before I oil it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR Metricon Liberty - Hampshire 45 QLD 1688Dec 03, 2017 7:14 am Those concrete supports are fabulous ??? Where from Re: KDR Metricon Liberty - Hampshire 45 QLD 1689Dec 03, 2017 1:58 pm brucefil2011 such a great job. What are the little concreate things called and where do you get them? galleriamad Those concrete supports are fabulous ??? Where from You can buy them from Bunnings. https://www.bunnings.com.au/deko-250-x- ... k_p1080391 Don't think I used them how they were intended to be used, but it surely does a good job =) Re: KDR Metricon Liberty - Hampshire 45 QLD 1690Dec 03, 2017 2:00 pm Renman Dude Looks like the professional did it for you. Great job. Looks like I’ll be flying you down for the decking and Orph down for the lighting at my place. Doulton777 Me too Ren. These guys are pro at what they do. hahaha thanks guys. Just book that ticket and I'm there =D Re: KDR Metricon Liberty - Hampshire 45 QLD 1692Dec 17, 2017 10:15 pm Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Re: KDR Metricon Liberty - Hampshire 45 QLD 1693Dec 17, 2017 10:38 pm heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Heat I was also successful with a aluminum slider door. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1694Dec 18, 2017 6:18 am heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. I originally had stacker and sliding door rebates but these were eventually cancelled by M when I told them I would be doing my own hardwood flooring post handover. If you’re like me and are doing hardwood flooring, they can’t rebate the doors because your floor will sit 40mm above slab level. One point to note is try to have the same type of doors. Ie Stacker/stacker, or sliding/sliding. Not Stacker/sliding. What I found was that the finished floor level of the doors varies for a stacker vs a sliding door. A stacker will sit 50mm above slab and a sliding will sit 40mm. If this is the case you need to change your doors or make sure you tell your site Manager to tell the carpenter to lift and pack under the sliding door an extra 10mm or else it’s outside of Building code to have two different finished floor levels. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1695Dec 18, 2017 6:21 am Dulie, Great job on the deck there! Looks amazing. Did you use Merbau? What’s the expected maintenance of the deck too? My landscaper is encouraging me to consider Modwood as it’s low maintenance but I’m not sure about it. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1696Dec 18, 2017 6:48 am Renman heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Heat I was also successful with a aluminum slider door. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t nomnomnom heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. I originally had stacker and sliding door rebates but these were eventually cancelled by M when I told them I would be doing my own hardwood flooring post handover. If you’re like me and are doing hardwood flooring, they can’t rebate the doors because your floor will sit 40mm above slab level. One point to note is try to have the same type of doors. Ie Stacker/stacker, or sliding/sliding. Not Stacker/sliding. What I found was that the finished floor level of the doors varies for a stacker vs a sliding door. A stacker will sit 50mm above slab and a sliding will sit 40mm. If this is the case you need to change your doors or make sure you tell your site Manager to tell the carpenter to lift and pack under the sliding door an extra 10mm or else it’s outside of Building code to have two different finished floor levels. So from your knowledge would this be acceptable? I may have to go back to M and challenge them but due to my limited knowledge I just took their word for it when they initially knocked me back. Re: KDR Metricon Liberty - Hampshire 45 QLD 1697Dec 18, 2017 7:59 am heatl0rd Renman heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Heat I was also successful with a aluminum slider door. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t nomnomnom heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. I originally had stacker and sliding door rebates but these were eventually cancelled by M when I told them I would be doing my own hardwood flooring post handover. If you’re like me and are doing hardwood flooring, they can’t rebate the doors because your floor will sit 40mm above slab level. One point to note is try to have the same type of doors. Ie Stacker/stacker, or sliding/sliding. Not Stacker/sliding. What I found was that the finished floor level of the doors varies for a stacker vs a sliding door. A stacker will sit 50mm above slab and a sliding will sit 40mm. If this is the case you need to change your doors or make sure you tell your site Manager to tell the carpenter to lift and pack under the sliding door an extra 10mm or else it’s outside of Building code to have two different finished floor levels. So from your knowledge would this be acceptable? I may have to go back to M and challenge them but due to my limited knowledge I just took their word for it when they initially knocked me back. I don’t know about tiling, Sorry. I think they should be able to rebate the slab to accommodate. I would definately challenge them. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: KDR Metricon Liberty - Hampshire 45 QLD 1698Dec 18, 2017 8:10 am nomnomnom heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. I originally had stacker and sliding door rebates but these were eventually cancelled by M when I told them I would be doing my own hardwood flooring post handover. If you’re like me and are doing hardwood flooring, they can’t rebate the doors because your floor will sit 40mm above slab level. One point to note is try to have the same type of doors. Ie Stacker/stacker, or sliding/sliding. Not Stacker/sliding. What I found was that the finished floor level of the doors varies for a stacker vs a sliding door. A stacker will sit 50mm above slab and a sliding will sit 40mm. If this is the case you need to change your doors or make sure you tell your site Manager to tell the carpenter to lift and pack under the sliding door an extra 10mm or else it’s outside of Building code to have two different finished floor levels. I am getting 19mm solid timber that will be a direct stick to the slab. When I got M to do the slider door rebate I advised that of the 19mm and they design the rebate to match the floorboards. I hope it turns out nice and flushed. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1699Dec 18, 2017 12:20 pm heatl0rd Amazing read D. My wife and I just started our Hampshire 45 build and it is such an exciting read going through your thread. I had a quick question, were you able to successfully get your sliding doors rebated into the slab? We got knocked back by M as being unable to offer it. Thanks, I'm glad you enjoyed the read =) As for your question, yes I got my sliding doors rebated into the slab. Wasn't any issues at all. Which state are you in? Re: KDR Metricon Liberty - Hampshire 45 QLD 1700Dec 18, 2017 12:23 pm nomnomnom Dulie, Great job on the deck there! Looks amazing. Did you use Merbau? What’s the expected maintenance of the deck too? My landscaper is encouraging me to consider Modwood as it’s low maintenance but I’m not sure about it. Thanks. Yes I went with 140 x 19 Merbau. I'm using Sikkens for the staining/protection. It has a yearly re-coat recommendation. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37586 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19387 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13709 |
