Browse Forums Bathrooms and Laundry Re: Where to put entry to ensuite 6Nov 22, 2017 6:01 am Option 2 is perfect, but even if you opt for option 1 you can insulate the room for sound by ensuring a solid core door is fitted, using seals around the door, sound insulate the wall and use "Soundchek" plasterboard. Re: Where to put entry to ensuite 7Nov 22, 2017 12:41 pm brokenstick We are having trouble deciding where to have our ensuite door. Option 1 (orange) is straight off off the bedroom Advantage - easy to get to Disadvantage - noise, I often get up early or come in late and my wife is a very light sleeper who doesn't like any noise There will be a door to the bathroom. Option 2 (white) is though the WIR Advantage - noise isolation between bedroom and bathroom Disadvantage - Bathroom feels very disconnected. Have to walk around and through long WIR to get there. If anyone else needs to get in they have to go through our WIR There will be a door to the bathroom. My wife favors this option, but to me it just doesn't look right With either option we will be having a door to the bathroom Will appreciate any input. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Option 2 looks better, but if your wife doesn’t like noise then 1 is the better option. Put a solid hinged door on the bathroom and soundscreen insulation in the wall. The WC isn’t big enough though, too squishy to close the door when inside it. Perhaps move the vanity next to the door and have the WC the way it is in option 2. You can have a high window above the vanity so there is room for a mirror. Building Monte Carlo 40- Wisdom homes Re: Where to put entry to ensuite 8Nov 22, 2017 2:16 pm Thanks for the replies and input - some good ideas and things to think about ! Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6479 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11917 0 10496 |
