Just wondering your thoughts on the Rawson inclusions and LUX package. How do you think it compares to other builders. Also what is the driveway allowance in sqm?
thanks
Approx. $130 a square metre for extra driveway.
Browse Forums Building A New House Re: Rawson Homes - General Thread 401Oct 30, 2017 4:27 pm Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: Rawson Homes - General Thread 409Nov 06, 2017 6:04 pm Building the Rawson Edge 39 MKI - https://forum.homeone.com.au/viewtopic.php?f=31&t=89729&p=1756917#p1756917 Re: Rawson Homes - General Thread 420Nov 15, 2017 8:12 am NBN installs that stuff (assuming you are in an NBN fibre area). NBN do have a preinstall program where you can ask the builder to ask NBN to install before you move in. But you need to initiate that and someone needs to be there to let them in. Rawson was ok for me with that, they organised the lot but our NBN is slightly different to standard as our NTD is outdoors installed in a meter type box. So NBN could do that without someone being home. If you are in a NBN fibre to the node or cable area then different story. Oh our install was different because our estate startered our as Transact rather than NBN, NBN brought their fibre network a few years back but Transact had to finish off the estate. So the estate is done to different install standards and Transacts install standard was outdoor NTD. Must admit I like it and am not sure why NBN doesn’t do that as the standard method for new estates. Would be hard as retrofit of course. You should check your detail drawings, it may show downpipe within brick pier. 14 14396 Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 3303 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11550 |
