Browse Forums Windows & Doors 1 Nov 04, 2017 9:30 am Hi all, due the combination of kids and football we now have a hole in a hollow core door and considering its a bedroom I am thinking its a good opportunity to switch to a solid core door to reduce noise transmission, improve feel etc. The door is a standard hollow core pre hung flush panel door from Corinthian. The concern I have with replacing it with a solid core door is whether the heavier weight of the solid core door is too much for the frame. The frame is a standard door frame by a volume builder. Not being a chippy I don't know whether a standard frame is built for the load of a solid core door or whether any more timber is needed. I am trying to find photos of the frame to compare this door frame with solid core doors in other parts of the house but in the meantime I am wondering if anybody could help me. Obviously I don't want to put the door on and find out the hard way the frame isn't up to it. Appreciate any guidance anybody can give. Thanks, Ronan Starting to build soon! Re: Replacing Hollow core with Solid core 2Nov 04, 2017 3:59 pm ![]() Hi all, due the combination of kids and football we now have a hole in a hollow core door and considering its a bedroom I am thinking its a good opportunity to switch to a solid core door to reduce noise transmission, improve feel etc. The door is a standard hollow core pre hung flush panel door from Corinthian. The concern I have with replacing it with a solid core door is whether the heavier weight of the solid core door is too much for the frame. The frame is a standard door frame by a volume builder. Not being a chippy I don't know whether a standard frame is built for the load of a solid core door or whether any more timber is needed. I am trying to find photos of the frame to compare this door frame with solid core doors in other parts of the house but in the meantime I am wondering if anybody could help me. Obviously I don't want to put the door on and find out the hard way the frame isn't up to it. Appreciate any guidance anybody can give. Thanks, Ronan ShaneG We have been doing heaps of hybrid floors lately. The hollowness is caused by low spots in the slab or subfloor. No slab or particleboard floor is going to be… 1 10975 ![]() Hi SouthiMonk, can I please ask if you have had Terramater Coastal blackbutt hybrid installed in your home, and if so, are you happy with the flooring? I was going to… 1 6096 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 22782 |
