Browse Forums Renovation + Home Improvement 1 Nov 01, 2017 12:35 am Hello, I am looking for a cost effective way to renovate door entry floor and 3 steps. As you can see the timbers varnish is worn down significantly, can this still be re-varnished? I was also considering laminate planks, but how would I do the nose of the stairs? Use something like aluminum nose trim?? Any suggestions? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Stairs and door entry floor renovation 2Nov 01, 2017 7:20 am You have real timber - do not cover it with laminate, which is a poor substitute. Hire a good floor finisher to sand and re-seal, and it will look great. Use a satin water-based polyurethane and it will have a very modern look (gloss if you want something more traditional). Re: Stairs and door entry floor renovation 3Nov 01, 2017 3:11 pm arcadelt is right, you wouldn't put laminate over nice timber like that and being such a small area you could easily hand sand that a bit at the time no real need to hire a sander if you're looking to save money, start a step at the time by the foyer should be easy enough. Maybe a nice shiny metal angle capping for nosing the thinkness of the stairs when finished nice would look good something like this look. There should be plenty of Youtube videos to give you a better idea. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6436 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11724 Move your linen into laundry and access laundry from your present linen space 1 8109 |
