Can you tell me what is the distance from a boundry fence to a carport wall and is there any regulations
Browse Forums General Discussion Re: Carport wall 2Oct 20, 2017 8:29 am Timbo12 Thanks for the photo but you need to provide more info if you intend enclosing the carport on the Boundary Then please check with your local council Building Department Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Carport wall 3Oct 30, 2017 4:05 pm Our wal had to eiter be minimum 900mm from boundary or on the boundary Your local council can give info and will also have to approve the plans for it to be build if its allready being build contact council with concerns they also have with our council a avenue to complain about and send out some one to investigate Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5253 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16179 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6933 |
