Browse Forums Owner Builder Forum Re: Advice for a steel frame construction [pole house on slo 2Oct 28, 2017 8:56 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice for a steel frame construction [pole house on slo 4Oct 28, 2017 6:09 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice for a steel frame construction [pole house on slo 7Oct 29, 2017 9:09 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice for a steel frame construction [pole house on slo 10Oct 29, 2017 10:22 pm You need the duragal version 7 matey. You are looking at version 6. https://www.onesteelmetalcentre.com/~/m ... ochure.pdf Re: Advice for a steel frame construction [pole house on slo 11Oct 29, 2017 10:27 pm If you considered alternatives to steel, you can use LVL's (use designit software). I have 3.3 cts for LVL bearers and using I joists which are spanning 4.0m (450 cts) Re: Advice for a steel frame construction [pole house on slo 12Oct 29, 2017 10:58 pm manofaus Here's the index link for duragalv Building Products flooring System spans for joist/beams only None of those brochures refer to Column support heights & engineering section property ...where specifically does it say 4.60m high because that's what KateG is asking for? "KateG How big are your poles and how far is the distance between them? Best regards Kate" Quote Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice for a steel frame construction [pole house on slo 14Oct 31, 2017 9:16 am KateG In the words of Chris Rock, "There's math and everything else is debatable" The same is said of Architectural/Artistic Rendering without data and proofs When you compare the various Steel Columns/Floor systems ie, Rolled sections (RSJ), Cold formed sections (CFS) things to consider,ie Site accessibility, material handling, Fixings,Engineering, Owner builder skill set, ease of fabrication, etc,etc BTW material costs for patented building systems are up to $10K/ tonne, RSJ $1k/Tonne and CFS $5k/Tonne Get the 3 options drawn/engineered/analyzed, work out the tonnage and do the math... you will see a clear winner OT i do admit the duragalv brochure does look impressive to owner builders...but you can get the same 3D details and instructions of your customised plans from my structural BIM software with data and proofs Make sure your Structural Engineer gives you the 3D BIM Model If you are starting from scratch get the whole Archi/Design, Engineering & Construction (AEC) in 3D BIM by someone who competent in all disciplines and avoid $ticker $hock. HTH Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Advice for a steel frame construction [pole house on slo 16Oct 31, 2017 9:11 pm KateG you are welcome..BTW if onsite material handling is going to be a problem then you might consider asking your Engineer about floor span truss design The fabrication costs of Light weight Trusses from China are low..HTH Please keep the forum updated..Thanks Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14434 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5314 Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8331 |
