Browse Forums Kitchen Corner Re: White Cabinets & Benchtop 5Oct 31, 2017 8:21 pm Here's some shots of my kitchen to give you a feel. Benchtops are Cesarstone White Shimmer Cabinetry is Polytec Polar White Sheen Photo after move in, can see contrast with stainless steel appliances, etc. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is kitchen at handover, with all the lights on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Up close prior to move in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10925 ![]() Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 42268 ![]() Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 13451 ![]() |
