Browse Forums Heating, Cooling & Insulation Re: Ducted refrigerated after handover for double storey 3Oct 23, 2017 9:03 pm Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Ducted refrigerated after handover for double storey 4Oct 23, 2017 9:25 pm Done it during the build, bit have also previously done another house after the build, had to make sure, ducts were in early and big enough, as air con ducts are bigger than the heating ducts. Re: Ducted refrigerated after handover for double storey 5Oct 23, 2017 9:36 pm Joker Done it during the build, bit have also previously done another house after the build, had to make sure, ducts were in early and big enough, as air con ducts are bigger than the heating ducts. I am getting them to quote me on upgrading the heating to sp5 so the ducts are bigger. Also 4 zones. They said I can then just add on cooling after. Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Ducted refrigerated after handover for double storey 6Nov 02, 2017 8:41 pm We are building a 46sq double storey. We have a quote for Brivis SP6 heating and Actron 19kw add on cooling (3 phase) for $19k. This includes 18 outlets, 4 multi controlled zones. The installer is installing the duct work during construction and then the heating and cooling post construction. Re: Ducted refrigerated after handover for double storey 7Nov 15, 2017 10:40 am becmm We are building a 46sq double storey. We have a quote for Brivis SP6 heating and Actron 19kw add on cooling (3 phase) for $19k. This includes 18 outlets, 4 multi controlled zones. The installer is installing the duct work during construction and then the heating and cooling post construction. Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Ducted refrigerated after handover for double storey 8Dec 10, 2017 3:50 am geminithinker becmm We are building a 46sq double storey. We have a quote for Brivis SP6 heating and Actron 19kw add on cooling (3 phase) for $19k. This includes 18 outlets, 4 multi controlled zones. The installer is installing the duct work during construction and then the heating and cooling post construction. Who are you building with? Building with Porter Davis. 1 4581 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9956 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 |
